Anjo goes 343! the daily project
Re: Anjo goes 343! the daily project
Post by volvodspec » 11 Dec 2009 03:41 pm
yep,
though i would have preferred to use the new style coolant system for the power loss of the fan. i am slightly adapting the current system hose wise though.
i've sourced a brandnew 343 1.4 radiator too and thought id would have been a waste to cut the frontplate up for the airflow of a late model 340/360 mk3 radiator.
i might have to remake the brackets for the PAS pump, i don't know if the old style waterpump conflicts with it, i guess i'll find that out with the B14.4E on the engine support.
also, i've made a deal for front and rear koni's, have new discs/blocks ready and all other parts of the steering/undercarriage will be refurbished/replaced and painted or powdercoated.
Post by macplaxton » 11 Dec 2009 06:43 pm
volvodspec wrote:and last but not least; a brandnew complete CVT clutch kit
How much do these cost currently (for future reference) ?
Post by macplaxton » 11 Dec 2009 09:26 pm
volvodspec wrote:little bit under €250
Thanks, handy to know. Was that outright or exchange?
Post by volvodspec » 18 Dec 2009 05:38 pm
outright, i paid 300 euro's and get 50 back if i deliver the pressureplate and clutchplate back.
towed it to my work today; including a 3inch snow package
went to work straight away but was reminded of the fact that paul had refilled the coolant with water to get the car at my door :lol:
pretty much frozen solid, lucky the coolant level wasn't at max so nothing blew/crack because of the ice.
i took of the head;
and reassembled everything to the .4E head;
back onto the engine;
and added a few more bits, coolant fan, radiator, alternator, airfilter, etc.
that's how it sits right now. i started off an hour too late this afternoon, would have had the car running by now :P tomorrow i'll finish it and start it up again.
Post by macplaxton » 18 Dec 2009 06:02 pm
Thanks for the info.
I see from those pics that the temp sender on those is at the back of the head like DAFs.
Post by volvodspec » 19 Dec 2009 12:45 pm
yep, all 300 with B14 and the old style coolant system had it at the rear of the cylinder head, with the new waterpump/radiator etc the sender was build into the waterpump; changeover was in 1984
build the last bits back together and filled everything up;
and then it started on the first attempt
really pleased with the result right now runs great again :D
Post by macplaxton » 19 Dec 2009 10:55 pm
volvodspec wrote:yep, all 300 with B14 and the old style coolant system had it at the rear of the cylinder head, with the new waterpump/radiator etc the sender was build into the waterpump; changeover was in 1984
1984? My 1982 1.4 Vario car with Smiths sender up front on the waterpump housing...
Post by volvodspec » 20 Dec 2009 02:08 am
that was a typo, i meant 1982!
in fact, the B14.2E engine could be equipped with new or old style coolant system!
that as M Y'81 343 with a b14.2E
(you can see this is a b14.2E by the exhaust manifold and the water nipple in the cylinderhead just above exhaust runner nr4)
but that valve cover on your pic is something i don't recognize straight away on a my 82-83-84 car, i believe those still had the two spring setup for zero throttle position (the last b14.3e i worked on had that) but can't recall that atm. do you have a overview pic of your engine bay? :D
Post by volvodspec » 29 Jan 2010 05:56 pm
the Renix unit;
carb matching the Renix with refurb kit;
both are from the same car as the b14 PAS kit came from, so all has been on the road since 1989 and seen 31000km of tarmac, its like new!!!
new headbolts, won't be neccasary since old ones are ok but when i'm busy....
new disks/pads
pistonring compressor tool
springcompressors and balljoint puller (i seriously don't know the correct words for that :lol: )
and 90 euro's for a valvespring compressor was a bit too much for a tool that is rarely used, so i spend some time in our machine shop and created the following:
in action
made a slight mistake creating a hole instead of a gap so need to do it again :lol:
this afternoon i filled the fuel tank up with RON98 unleaded, exactly 40liters went in; just in time at the fuelpump! :)
after that, went to my work for a complete check of the car from underneath.
checked oil levels in cvt gearbox, secundairy had old engineoil in it so that was replaced with proper 80W90
Primary gearbox had old oil in it, replaced that too.
few chassispics:
small hole in the mudguard (or whatever that is called)
apart from the tiny hole on the mudguard the chassis is solid as a rock, very very pleased with that!!!
adjusted the clutch:
airgap was waay to big. now with 2mm of adjustments plates the airgap is perfect and driving is way better. also noticed that the gearleverplay is in the primary gearbox, too bad. that means i'll have to keep selecting P first before going to R..
when i went off the car barely moved, so checked the brakes/suspension
and on the brigde next to it, is a Terberg FM2850 that i put together earlier this week :D
there was some rust on the discs, so had a run around the block with the brake slightly applied and now the discs are clean and shiny.
when i drove it onto the bridge and turned it off i noticed a shhhhhhhh noise coming from under the hood.
when i placed the .4e head onto the .1e block the hose from carb to head was plugged since the .4e head doesn;t have that hose connection. the hose was now blowing up and coolant dripping onto the exhaust manifold :lol:
fixed it with a few new hoses, pics below. also i had a floaterchambergasket lying spare, so took the carb apart and gave it a good clean.
loctite for the floaterchamber bolts ;)
and the new hoses:
the engine ran slightly rough so after all other work i adjusted it and now it runs perfectly smooth;
that's it for today! the 343 drives great again, ready for my dad's daily use :D . that also means that the red 340 will soon be taken apart, drove 200km with that last weekend and that also drives excellent, but all for the greater good :D
Post by volvosneverdie » 29 Jan 2010 06:03 pm
Im still amazed at how solid that car look underneath dude.
Its amazing. :)
Post by Speedy88 » 29 Jan 2010 06:11 pm
Excellent work dude. This car is epically clean. I swear it's been wrapped in bubble wrap it's whole life :)
Post by volvodspec » 29 Jan 2010 06:24 pm
for a 1980 it's especcialy rare! but the 340T from 86 is even harder underneath :D
turnbullj
Post by turnbullj » 29 Jan 2010 06:38 pm
really clean looking car well done, where do you get your carb rebuild kits from?
thanks James
88 Volvo 340 DL
55 Fezza Zetec S
Post by volvodspec » 29 Jan 2010 07:05 pm
a dutch company, specialized in carburattor parts http://www.bccp.nl.
brand of the kit for the 1.4 carbs is:
Meat & Doria special parts
W250.2 Weber 32 DIR
part no: 803341908343
