Brake fluid
Brake fluid
Post by Tom »
Is there some kind of floating sensor inside the brake fluid tub? I ask because my brake fluid warning light flashes momentarily every now and then, and the fluid level is waaaay above minimum.
Cheers for any replies!!
F983 OHD '88 340DL - Gone but not forgotten
C299 LGF '86 340DL - Variomatic jerkiness
wjp01908
Post by wjp01908 »
Yes there is.
If it`s full, chances are the you have a short to earth or the float switch is dodgy.
Will
Post by Tom »
Cheers Will! :) I'll have my auto-electrician friend look at it tomorrow.
Carl
Re: Brake fluid
Post by Carl »
Do you have wear sensors on the brake pads? Cant remember if my 360 did or not. Could be them if your pads are low and it happens when braking...
Carl
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
Re: Brake fluid
Post by Tom »
Carl wrote:Do you have wear sensors on the brake pads? Cant remember if my 360 did or not. Could be them if your pads are low and it happens when braking...
Carl
Not that I'm aware of. I'll 'ave a look tomorrow. Cheers for your reply. :)
Don't think they do.. my '86 Metro did.. what a POS, howver.
shimon340
Post by shimon340 »
Hi
340s dont have any brake pad warning system
the only reason the brake fluid light comes on is
a) the fluid level is getting low
( its comes on if the level is half way between max and min... i had a 340 where the level was between min and max and under acceleration the light would come on )
b) short to earth of the sensor
c) faulty sensor
good luck!!!
keep us posted what you find out
Shimon
Enjoy your 300s
Fuse
Post by Fuse »
Brake warning light (!) also comes on when the oil warning light comes on. It's because the brake warning light wouldn't light up when you turn on the ignition power without that system. There is a jumpwire from earthing of the oil sensor to the brake warning light's earth and it has a diode in it so the oil light won't come on when the brake light does. :P
Post by Tom »
Shimon, the brake fluid is around about half way, and it only comes on under heavy acceleration. That must be the problem. Cheers mate.
shimon340
Post by shimon340 »
Hi Tom!
Its a pleasure to help a fellow 340 owner!!!
BTW the light acts as a nice accelerometer in these cases... but it does tend to scare the passengers coz as you accelerate, the brake warning light comes on!!!
Enjoy your 340!!!!
Shimon
Enjoy your 300s
Kakemnstr
Post by Kakemnstr »
sorry to drag up an old thread, but is there anyway to test if the brakefluid(!)-light is working ? :oops:
pettaw
Post by pettaw »
The black rubber bit on top of the reservoir with an electrical sensor coming out of it is a tester, press it hard whilst the engine is running and the brake level warning light should light up.
