how can i increase the hp on a B19E
hello guys ..... how can i improve a B19E engine ..... to gain power without makeing it a turbo engine or replacing it ? any ideas, please help me if you can..... the only thing that i have changed to the engine was the air filter .....i have change it with a fiber carbon injen filter
- volvodspec
Re: how can i increase the hp on a B19E
imo best way to get descent power out of a b19e is go for twincarbs (and adjustable fuel pressure regulator, use original fuel pump); better exhaust manifold and downpipe, custom ignition unit, a cam to suit the twincarbs and dynoadjust the whole lot
should be good for 170/180whp
i don't have a carb.... i have this engine ... it's from 1983 from a GLE
- volvodspec
yeah i know, but the stock ignition isn't that great from tuning perspective. and the above is pretty much bolt on-modifieing
a lh2.2 or 2.4 conversion could also be considered; together with the correct amm, throttle body, cam and exhaust you should be able to get a nice result too. more work and less cool if you've heard the sound of twin carbs on a 2.0
you are sugesting to put a engine of 2200cc or 2400cc and to remove this one ?
and were can i find some cams for this engine or for old volvo engines .... in my country i can't find any ..... can you point me to a online shop ? if there are any or a shop were can i find some parts to modifie this engine or a old vlv engine ........i am having a hard time finding parts.....
- volvodspec
no lh2.2 and lh2.4 are "newer" redblock injection systems way more superior than the stock 300 series injection; check this thread: http://www.volvo300mania.com/forum-uk/v ... ilit=lh2.4
so .... lh2.2 and lh2.4 are engines that are found on the 700 series and 200 series ?
and can i convert the b19e into one or just need a new one ? sorry for asking so many questions but i am a student and i need to modifie my car so i can enter a racing club and go to legit races .
- foggyjames
LH2.2 and LH2.4 are engine management systems. A B23 or B230 is the 2.3 litre engine found in 240s and 740/940s (respectively).
I think the twin carb idea is a good one. You can buy special fuel pressure regulators designed to reduce the pressure down from an injection pump for use with carbs.
Tuning comes from increasing the breathability/air flow of an engine, everything else is simply to support that (eg the right fueling).krazvy wrote:i don't have a carb.... i have this engine ... it's from 1983 from a GLE
Twin carbs do not increase power themselves, but can perhaps with a less restrictive manifold. IMO the injection system is not bad, but you might fit a 940 turbo injection manifold if you can up the air flow. Mainly on a normally aspirated car you need a different camshaft there are a few tables around which can indicate where to get them. I have a spare A cam, but its not the best. You can see the rating at the end.
My advice is stick is a straight through exhaust on, it will feel fast and fun, even if it doesn't actually add much power. If you bother with a cam change, the injection system should work just fine with it until the air flow meter maxes out. Its an analogue computer based system not a memory mapped one like LH2.4, so it won't run out of 'map knowledge' until the sensors max out.
- foggyjames
The NA and turbo EFI manifolds are identical as far as I know (except some have a cold start injector, etc...but for performance they're the same...).
Andy's Megasquirted 10:1 compression B200E with a K cam made 122bhp (if I remember correctly). On the same dyno, my 9.2:1 B200K with twin carbs (Solex carbs similar to Weber DCOE 40s) and a K cam made 140bhp...so there's a useful gain to be had in ditching the standard inlet manifold.
- volvodspec
twin carbs definatly will improve power themselves! but, like any type of NA tuning it will work at it's best if you combine a good combo of parts.Ride_on wrote:Twin carbs do not increase power themselves, but can perhaps with a less restrictive manifold. IMO the injection system is not bad, but you might fit a 940 turbo injection manifold if you can up the air flow. Mainly on a normally aspirated car you need a different camshaft there are a few tables around which can indicate where to get them. I have a spare A cam, but its not the best. You can see the rating at the end.
the twin carbs provide more air + more fuel (cause of more air)
the better cam will make sure that this bigger amount of mixture gets into the combustion chamber properly
more mixture means a longer combustion time; for better power the ignition needs to be improved so that it ignites the mixture at the correct time preventing detonation and achieving max power
the better exhaust manifold/downpipe lets the engine get the gasses out easyer; and has a better tubular configuration to help the other cylinders with the combustion
the advantage of the twin carbs way is that it's all bolt-on tuning with a dynorun at the end to setup the carbs and ignition, imo a improved engine management (like lh2.4) is way more work with less result compared to the twin carbs
how could i go about upgrading the ignition?
85 360 GLT drift beast
clutch kicks ahoy!!!!
- volvodspec
for a hot cam + twin carbs you definatly need to ditch the original Renix, you can advance all you like; the curve is waaaay off so it will allways misfire/backfire, instead a new ignition unit such as the 123-ignition models can be used; these can be programmed for a spefic engine setup
This doesn't necessarily mean by default the car will be quicker every day... comparing these two cars together from standstill/low speed upto about 70mph they were very, very similar due to the flexibility that modern EFI has to offer.foggyjames wrote:Andy's Megasquirted 10:1 compression B200E with a K cam made 122bhp (if I remember correctly). On the same dyno, my 9.2:1 B200K with twin carbs (Solex carbs similar to Weber DCOE 40s) and a K cam made 140bhp...so there's a useful gain to be had in ditching the standard inlet manifold.
I also believe the dyno figure of 122bhp was the original B200E with A cam, I thought anyway.
