So on with the belt cover, aux. belt, new (well nearly new) rad. and fan etc, refill with water and the moment of truth....will it run ?
Running fine, in fact sounds smoother than before! Old belt was very old and done too many miles.
So, chuffed with my first solo cambelt change I thought I'd celebrate with a much need coolant flush and oil change.
Flushed coolant, not too dirty to say it's sat in there 6 years! (but not many miles) Then drained oil (pretty clean as it only did 8000 miles before car was taken off road) and put in flushing oil. Refilled with new coolant and then oil after fast idle for 10min. Checked for leaks. Coolant Ok. But whats this? a fine spray of something wet off the sodding engine. At first I thought it was water but then found it was OIL
How the hell could changing the oil cause a leak? I didn't spill any on the engine and it wasn't there before the oil change.
But there it is, a very fine spray coming off the crank pulley all over everything in line with it, including my face
Now the car never used to leak, yes there was a lot of old sticky oil from minor leaks over the last 120,000 miles and 20 years, but it never dripped or sprayed oil like this before.
Ok I thought, is it crank shaft oil seal or cam shaft? So off with the timing cover. There was quite a streak of oil from the cam shaft area but after wiping it barely came back, so maybe crank shaft? Still oil spraying and now dripping onto floor. This really starting to p*ss me off.
I left it running for a while to see just how much oil it was loosing, and if it would get worse. I was just wondering how big a sponge I would need to hide in the engine cover to soak up the oil during an M.O.T.
As if by magic...no spray of oil and drip stops
I don't believe it, so I run it at 2000 rpm for 60 seconds and yes, no more oil.
Anyone had this before?
My ideas are,
1) Flushing oil has damaged oil seals (maybe short term effect)
2) Over zealous cleaning of old oil gunge around seals that was preventing/ soaking up oil leaks
3) Too rapid filling of flushing oil (which is a thin oil) in cam cover leading to short term build up of oil there which leaked through cam seal (which has had a long term slight leak). This oil then flowed down to crank shaft and pulley and has now all been sprayed off.
Sorry for long post, but it's a tricky one!
