Has anyone fixed a custom built Power steering rack in to a non PAS 340?
Is there any Japanese PAS that can be fixed ?
When will you be fixing ? did you purchase a rack?Speedy88 wrote:I've been planning on fitting one myself, the ones from Corsas are mean't to be good. It needs to be electric I think.
macplaxton wrote:Steering shouldn't be that heavy on a 1.4 - sounds like an underlying problem.
Corsas all have rack & pinion steering, always have done and probably always will. However the versions that come with PAS use exactly the same, unassisted rack as the pov-spec versions, the assistance is by electric motors that operate on the column, so the rack isn't relevant and that's how the system can be adapted to work on cars with boxes too.Speedy88 wrote:Don't think Corsa uses a rack.....
360 PAS rack with a few brackets, pump, labour and a £1645 quid (1990) price ticket.JPB wrote:What system was it that was fitted to some Motability-supplied 340 Varios in the '80s then?
Why would you want to though? The Corsa doesn't have an assisted rack, its PAS acts purely on the column, the point being that a Corsa steering column can possibly be used to add assistance even to cars that have a box and idler system. But that column is pretty bulky and having had a look at the space available on the 340's bulkhead and under the dash, you'd need to remove the fuse box from the bulkhead, make a large hole where it used to be, relocate the fusebox, replace the 340's lower column joint with one that would mate it to the Corsa column, fabricate and fit a tubular steel reinforcement to replace the strength lost in cutting away chunks of the bulkhead..... There's more, and the wiring would be the simplest bit of all.shamil wrote:......
Can we fix Corsas Rack & pinion steering with some modification
