everything a fiver or an offer! just out of uni and no money
360 rocker cover
940/740/240 exhaust manifold, will probably fit 360.
940/740/240 sump and stiffener bracket
heat shields for the same
starter motot, all red blocks good working order
940 oil pump, probably all red blocks again. will fit 360 with the pickup pipe swapped over.
power steering pump, probably all 2/360/7/900 series with engine bracket
940/740/240 engine mounts.
water pump, heater pipe and pully.
all bits came off an m reg 940 b200 on lh2.4 injection unless stated. ie rocker cover!
Ben
