Removing Door Pins?
Justin
Removing Door Pins?
Post by Justin » 03 Aug 2010 04:38 pm
Do I need a special tool to remove the door pins and if so where can I get one?
1988 340 1.4 DL
crazycat
Re: Removing Door Pins?
Post by crazycat » 03 Aug 2010 05:24 pm
you wont need a special tool, only a punch or drift pin, you'll have to push from top to bottom
Post by Ride_on » 03 Aug 2010 07:37 pm
The top pins can be removed with a punch or old screwdriver, you need to lift off (carefully) the rain gutter strip top gain access. Once half way through use a new pin to finish and follow the old one out.
The bottom pins really need a door pin removal tool to remove upwards. I got one from ECP and it just about lasted for the 2 bottom pins. They are quite hard to get out.
Justin
Post by Justin » 04 Aug 2010 02:35 pm
Thanks, who are ECP and do they have a website? Also what size drift pin would I need? Surely someone on here must know!
Also this tool is advertised on ebay, I wonder if it will work on a Volvo 340?
1988 340 1.4 DL
Post by Ride_on » 05 Aug 2010 12:13 am
looks pretty much like the one I got, didn't last very long. Those pins need serious removal power.
ECP - Eurocarparts, one from frost.co.uk might be better
http://www.frost.co.uk/item_Detail.asp? ... %20Remover
Post by macplaxton » 05 Aug 2010 12:53 am
Ride_on wrote:looks pretty much like the one I got, didn't last very long
The bar or the pins? Pins are usually available separately as spares.
Justin
Post by Justin » 05 Aug 2010 02:59 pm
Does anyone know what size punch I would need, 8mm possibly? It doesnt say in my Haynes manual.
1988 340 1.4 DL
Post by Ride_on » 06 Aug 2010 02:28 am
You can just hit the edge of the pin, you don't need the full size, although with a crappy punch the corners will wear off.
Justin
Post by Justin » 06 Aug 2010 02:57 pm
I measured across the diameter of my replacement pins and they're 1/4". Im hoping Kevin Coopers will do a drift or punch thats the same size...
1988 340 1.4 DL
Post by trabitom99 » 06 Aug 2010 03:18 pm
Hi Justin,
there are some posts with some good info on door pins on this site, check out these threads:
http://www.volvo300mania.com/forum-uk/v ... f=5&t=3615
http://www.volvo300mania.com/forum-uk/v ... f=5&t=8606
Justin
Post by Justin » 07 Aug 2010 02:23 pm
I just need to know what size punch I will need in millimetres?
1988 340 1.4 DL
Post by Ride_on » 08 Aug 2010 03:09 am
Any punch bigger than a few mm will do. Whatever size you use you need a good hammer blow, that is the most important thing.
Justin
Post by Justin » 30 Jan 2012 05:23 pm
Has anyone actually used the hinge pin removal tool that (http://www.frost.co.uk) sell?
1988 340 1.4 DL
