changing the carb webber 32/34 dmtl
matt~driver
Post by matt~driver »
Hi I have a Volvo 2.0 360 and was thinking of changing the carb ive hared that the webber 32/34 dmtl is a straight swap for the one I have on at the mo is this correct and if so dose any one now the jet sizes would work on my 2.0
Re: changing the carb webber 32/34 dmtl
Post by volvodspec »
why would you want to change it?
on the B200K the Solex Cisac 34-34 that is currently on there is actually known for it's reliabilaty and low end torque capabilitys, the only common problem it shares with the Solex Cisac 28-34 of the 1.7's is the floater wich is actually the only weak point in the entire 34-34 carb (but after replacement and correct adjustment it's not a problem anymore)
anyway, a weber 34-34 might work but if you really intend to swap it out and rejet it for that work + costs, i'd seriously consider an injection conversion from a B200E engine...
