that 360 gl is fu**ing sweet dude!!!!Nikdev wrote:What do i win?![]()
More whoring of my two ex cars...![]()
-9cm up front(intrax dampers, cut dai springs)
-9cm rear(modified leaf spring, spax dampers)
13x8 rims
All custom...
pics of your lowness please
Re: pics of your lowness please
better one of mine on standard mk2 steels with 155/70s
plans to go lower beginning of next year via tubbed arches and modified leafs
valman wrote:better one of mine on standard mk2 steels with 155/70s
That looks epic like that, but sadly it's just a fact you can't get these "properly" low as the floor/chassis design just doesn't cater for it like a lot of cars, i.e Golfs, Chevettes etc. I reckon if you are genuinely going to tub the arches and moddify the leafs surely you are going to need to raise the floor aswell
Thanks!
was thinking of getting rid of the air channels for th CVT cooling first by cutting them out and welding in a 3mm plate or something thatll get an extra inch i hope then go from there, basically whatever gets in the way goes
Spot on, i got a Chevette/Kadett C as its called here in Norway, it has the same clearance to the ground as my blue one and that still needed to go down some cm, but the Kadett i decking the same rim/tire combo...magnumpi wrote:
You need to seriusly modify the exhaust on the 360 to get it low enogh, maybe build a exhust tunnel, as there is limited space, side exhaust is not a option, I had it on the red one and it was just silly
But I recon 14`s or 15`s are the best on 360, here`s mine with 15x8 et0:
Nikdev wrote:Spot on, i got a Chevette/Kadett C as its called here in Norway, it has the same clearance to the ground as my blue one and that still needed to go down some cm, but the Kadett i decking the same rim/tire combo...magnumpi wrote:
It's a shame though as your blue Gl is the bested stanced 300 there is/was IMO, it just works so well. Helped by the fact that the base car looks so clean and tidy in the first place
My mates Chevette was ridiculously low compared to my 300 but drove so much better without all the bashing and crashing through potholes (sadly unavoidable in the UK due to the sheer number of them
Just a quick Q, that last pic have you pulled the inside lip outwards, or just rolled it in a heath robinson manner
magnumpi wrote:
It's a shame though as your blue Gl is the bested stanced 300 there is/was IMO, it just works so well. Helped by the fact that the base car looks so clean and tidy in the first place![]()
My mates Chevette was ridiculously low compared to my 300 but drove so much better without all the bashing and crashing through potholes (sadly unavoidable in the UK due to the sheer number of them) and yet still retained a comfortable ride, where as 300's antequated cart springs do it no favours.
Its rolled with a vengeance, tried to fit some weller`s with a pretty low offset...
Got them to fit;)
volvosneverdie wrote:^ Sir, why did you sell that car!!!????![]()
I will be back, I am actually chatting with the new owner of it on fb these days, he is taking good care of her..
But as i said, 13"`s at the right hight its just special
your red 360 has given me such great ideas love your blog credit to you mate
here is a comparison of mine to a standard height one (mine aswell
) same wheel/tyres
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
