gearbox's
samueljon
gearbox's
Post by samueljon »
4 speed gear box to a 5 speed gear box...
straight swap??
its bolting onto a f7r (1.8)
Re: gearbox's
Post by volvodspec »
jup straight swap if the 5spd is from a 340
360 gearbox requires a bit more work to convert to 340 fitment...
samueljon
Re: gearbox's
Post by samueljon »
na ill be finding a 340 gear box save the messing about :)
Re: gearbox's
Post by Ride_on »
I assume you are getting the diff aswell with the gearbox. 5 speeds diffs are a different length to 4 speeds ones.
Re: gearbox's
Ride_on wrote:I assume you are getting the diff aswell with the gearbox. 5 speeds diffs are a different length to 4 speeds ones.
Really? Propshafts certainly are, I've never noticed a difference on the diff. It is easier to swap the box and diff as a single unit anyway.
Re: gearbox's
4 and 5speed propshafts are the same, the only variety is between CVT and manual.
gearbox + diff have the same overall length is you compare a 4 speed to a 5speed,
the difference is that behind the gearbox's 1,2,3,4+R section the 5th gear unit is placed, making the gearbox aproxx 10cm longer. this length issue was solved by shortening the diff
samueljon
Re: gearbox's
Post by samueljon »
well i would aim to get everything together to make it easier
after going though the "learning curve" stage and getting a little cockey i have to find another one thats all :(
Re: gearbox's
I stand corrected :D Never knew that, I've been lucky enough to not own a 4spd ;)
Re: gearbox's
Post by Ride_on »
One thing I don't know is if you can use a 4 speed box in a 5 speed, ie leave the 5th gear section in and just replace the main gearbox?
Re: gearbox's
I imagine not because it must have extra linkages. Could be wrong though, I'm not hot on how gearboxes work.
Re: gearbox's
nope, not possible.
the first 4 gears and reverse can be seperated and used/fit, but the 2 main shafts have different lengths so you need those from the 5spd box..
