can you get these pipes re-built at a local more spares place, ive seen kits on ebay but not sure if thats a good idea haha
brake re-build?
brake re-build?
As i was stripping the brakes back i found out that all the pipes from the servo are shot
Re: brake re-build?
Yes, its pretty cheap. I'd suggest a brake pipe kit consisting of a flaring tool, pipe cutter, some nuts and copper(ish) piping.
You can get most garages to make them up aswell, but they need the original pipe or a measurement to go buy.
BTW there are no brake pipes 'from the servo', I presume you mean the master cylinder, or are you talking about the flexible hoses at the callipers?
Re: brake re-build?
Most engineering works have carried out such manufacture since the dawn of time, And at surprisingly cheap prices. Best to take the old one in its original shape to get a good copy, given that manufacturing of copper and steel pipe has increased over the last 4 decades you'll get better quality than OEM at an engineers. i'm lucky to have frank edwards less than a mile from me.
Re: brake re-build?
ye i saw the kits on ebay with a cutter,bender and flare tool
and yes sorry to the master cylinder then it goes down to a "junction" where it does the near side brake and goes of to the rear
Re: brake re-build?
samueljon wrote: "junction"
Magic Pixie Valve (tm)
It limits the amount of rear brake application so you don't pirouette off into the distance after locking up the rears.
Re: brake re-build?
Just be aware that the cheap kits on eBay are pretty useless. I had one that the flaring tool broke apart in my hands upon first use, and a mate had one where the flaring bits sheered off after a couple of uses. If you're going to get one buy a half decent brand.
Also, not passing it on as fact, but I have been told that the best pipe to buy is a copper-nickel mix and always have. Does the job anyway.
Re: brake re-build?
The copper nickel is very rigid and slow to corrode.
Re: brake re-build?
cheers guys, ive got my local garage to get me some made up
