Anjo's 340Turbo: EFI conversion
Re: Anjo's Project Car: 1986 340GT Special, B14Turbo
Gut werk Anjo
Good work as always mate.
cheers guys
manifold was all done
so i reorganized the shop a little and took the engine bay out of our garden, that last bit made my mom very happy
after that the B14.4T went on a stand and into the workshop
oildrain, drilled at an angle
welded, had to correct it with feed at one place because the hole was a bit oval, shame because it was a beautifull weld
so here's why it needed an angle
you can also see that because of the oval hole i decided to weld the other end of the flange too.
first bends to align the pipe
and the last piece welded on wich lines up the 2 pipes perfectly. this last bit also has a ring on it to clamp the hose in place.
wastegate bracket also done
next are a few braces for the manifold and it's time to order a few parts for the oil feed and downpipe
Damn that looks great!
Good fabbing skills as ever dude.
amazing fabrication work!!
Keep it up!
Keep it up!
yesterday´s work
plan is to finish this entire sub-assembly today, have to attach the throttle cable support and weld hose humps to each pipe to prevent the hoses from blowing off the pipes and after that clean the entire thing, grind the excess bits etc. think it will look good when it's all done
I love those stainless water pipes - so much better than the stock rubber hoses that always leak and are impossible to get hold of!
alingned the 2 V-band flanges, had to skim a bit off the converter that bolts to the turbo on the lathe
welded the first bend to the V-band flange
studs for the turbo were too long, so i shortened them and added thread on the right side to make them perfect suiting
finished the wastegate actuator bracket
flanged the stainless coolant pipes, also redid the long one from turbo to waterpump on the post above as i was afraid this one would fail over time; this now consists of 2 pipes.
welded a pair of manifold support braces
pre-assembled the whole lot
out with the old engine; the overhead crane (2x 6,5T) was a bit overkill though
and here comes the 6-cyl Mercedes Benz turbodiesel and ZF 9-gear powershift transmission conversion...
in fact, with just the gearbox the engine bay was full
in with the B14.4T
and nog i'm waiting for parts, my hands are itching to get this thing going again
in with the B14.4T
i bet dude work looks good i rely am thinking of doing a welding course next year
Write it in your heart.
The code of the West.
Sweeeeeeeeeet
tiny update, it's slowly coming together.. wish i wasn't stuck with the flu this week. would've been a lot further by now
and again, stuck waiting for parts
depending on the weather i'm going to start on the downpipe.
made radiator support bracket as with the 2 bottom mounts alone the flex in the frontbeam's steel was a bit too much
stainless steel offcourse
now it's solid as a rock i can even stand on it
stainless bolts for the alternator were still missing, so i made a new set
so no more of this:
all together:
will need to get another cooling fan powdercoated, since this one was damaged when one of the bolts ran loose..
and started on the fuelling, uprated fuelpump and a kingsize fuel filter. old vs new:
i won't make mounts for it till i know where they'll end up under the car though
so no more of this:
all together:
Hi Anjo.
Your work is fantastic. Well done.
Is this thread ever going to get a 24th page, this page is so long ha
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
