hi, just come to do the wheel bearing on my 340 but ive stopped as i cant get my head round and need help, ive done a search but cant find anything, has anyone got a guide? or could someone explain/talk me through it please? anyone got any pics or anything that could help? the cars sat on axle stands on my drive so i need help asap please
wheel bearing help pleaseee
Re: wheel bearing help pleaseee
It's explained pretty well in the haynes manual. Take off the grease cap, undo the hub bolt, remove all 6 bolts holding on the calliper, remove calliper, pull off hub assembly, pull out bearings from front and rear of hub, rear will need a screwdriver to punch it through from the front, insert new bearings with LOTS of fresh grease, bolt everything back together making sure hub slides ALL the way back into the housing.
Easy.
Easy.
- volvodspec
take the driveshaft off and remove most of the CV joint's grease thats left at the wheelside
undo the big nut that's beneath it and lower the car to the ground to get the wheelbolts loose
take the brake drum off and now it's flamethrower and pulley time.. use the pulley to pull the 6-bolt driveshaft flange off the mid axle where you undid the big nut
gently put tension on the flange with the pulley and apply heat with a torch to melt the Loctite that secures the wheelbearing. after a while the pulley should undo the driveshaft flange with ease. now you can remove the bearing shells etc. clean the whole lot and mount the new bearing. make sure you secure the outer and inner shell off the bearing again with Loctite 620 or 638!!!!
- volvodspec
edit..
Speedy's guide is for the front, mine is for the rear
lol, cheers anyways im sure it will come in handy, cheers guys, anyone got any pics?
While we're on the subject, anybody know by heart the mm size of the front hub bolt? Need to go and replace some tools tomorrow and I'd rather not buy every single size between 20 and 25
- volvodspec
My rears where not held on with any material atall (later one piece sealed bearing). You simply push the axle out with the puller, this destroys the bearing inner cage, and the outside track has to be ground off the axle carefully. The rest of the bearing has to be hammered out from the aluminium hub, and the new one installed using temperature difference (hub at 180C and bearing at -20C). Re-assembly is a one time operation so include the brake back plate with axle/wheel flange.volvodspec wrote:take the driveshaft off and remove most of the CV joint's grease thats left at the wheelside
http://www.volvo300mania.com/forum-uk/v ... el+bearing
hey guys not had chance to come on here for a while, sorted the wheel bearing out with your help so thanks very much
