Ok, I'm not saying nothing moves when I say fixed, but just starting from that consideration. Now I still don't see the point in using a slider on a prop that may move minimally, I'd use something rubber. Hell, if you have to change a rubber coupling of some sort every now and then, I don't see that being a big deal, providing it is easy to change (which on a standard prop isn't).jon-ovlov wrote:he wouldn't warranty the prop without the slider, as UJ's aren't meant to take forces in that direction.
Any idea what the weight difference is between a bog standard and the custom prop? Must be some inertia in a steel prop. Two-way street as well, heavy acceleration will wind its way back to the rear, heavy braking will wind its way forwards to the engine.
When you find it....bung it up. I thought I seen one too, but I could be going mad here.jon-ovlov wrote:I remember seeing a twisted prop once too. Bookmarked it somewhere.
Brings us back round to why Volvo amongst others have resorted to a torque tube on this layout.jon-ovlov wrote:I'm sure the reason the box failed is because the engine is able to move, however the gear box is not, at least not enough
They only take up the shock during clutch engagment outside of that window, the clutch springs do nowt. Say you're at the bottom of the hill in second gear and floor it...they wee springs aren't doing bugger all.Chris_C wrote:Shock damping I'm in two minds about, in theory, isn't that what the clutch springs (in the friction plate, not the pressure plate fingers) should be doing?!
