wanted: B200 water pump and pulley
joel142
Post by joel142 »
Hello from across the pond!
I'm looking for a B200 water pump and pulley from (I think) a 360. I live in Seattle, Washington in the US and I've put a B230FT into a 142. It runs and drives, but, there's very little room between the water pump hub and the radiator. Even after moving the radiator as far forward as possible a flatish mechanical fan just barely fits. I'd like to use an electric fan and that requires more space. The trick others have used is to install the stubbier unit from a B200. Now, not getting the engine or car in North America can complicate things a bit. If anyone has a line on one here, that would be great. If you have any interest in any NA parts I can probably arrange for that.
Thanks
Joel
