car dies when turn lights on.. 1.4 340 please help :)
phayth
Post by phayth »
so my volvo has been going pretty good for a month or 2 until now, i was driving the other night and flashed my headlights to say thank you to a car that pulled in to let me pass and everything just died and wouldn't start. luckily it was outside my girl friends house so i went in had my food and came out... started first time! thought it was strange but hey it was working again...
the day later i started my car after finishing work, (been working fine all day, with out using lights) turned the lights on and it died again, this time i wasn't moving and it died with the choke on as i was letting it warm up.... again started ok 10 mins later....
then when i got up to work the following day it started fine, then you guest it died when i put the lights on... and i havent been able to start it since...
so basically when i turned the lights on it kills the engine, but everything else still works, radio interior lights etc.... but now when i turn the key the only thing that does work is there are no dash lights at all..
i am thinking ignition switch?
is this a common fault or has anyone had this before?
any help is much appreciated. thank you :)
p.s checked all the fuses and all are ok.
Re: car dies when turn lights on.. 1.4 340 please help :)
Post by macplaxton »
First idea leaping to mind are the big wires at back of fuse box/dodgy multiplug?
Do a search top right here, it's common enough.
Cheers Chris, glad someone knew where down the back of the sofa that thread was.
phayth
Post by phayth »
thank you very much lads! ill have a look tomorrow and get back to you :)
