I have started to collect parts and making parts.
So here goes.
Manifold as bits
Turbo charger and manifold made
5 paddle clutch plate
HD pressure plate
I will be using a 360 torque tube and gearbox hopefully with PG copy LSD.
My bell housing and adaptor plate is getting machined at the moment.
I'm hoping to go and see Alan tomorrow so that I can take a photo of the receiving Midas.
This is not actually the one but Midas mk1(Bronze) is this kit car model.
I have to shorten the torque tube and propshaft. Then adapt MX-5 rear suspension/subframe to carry 360 gearbox instead of just a diff housing.
Like I said, I'm collecting parts for the moment as I have my other project to finish as well as 3rd baby on it's way next year.
So I will be busy boy for next few years and keep missus happy by not disappear into my garage/workshop too often!
Hi,
OK, the above photo is actually mk2 Midas.
Here is my new car... well old but new to me.
I think wheel base is 300mm shorter than 360 so I have to cut a lot out of a prop and a tube.
It is a 2+2 setup but I think I will lose 2 seats at the back due to the gearbox and the diff under neath.
I'm hoping to use 185-55/14 tyres so that I can do side way fun! What tyre sizes does everyone use for their motor?
I left my parts below to a machine shop so that they can mill it to fit nicely to each other.
You can see that bell housing of 360 have been chopped and the other one is my half Gti gearbox casing.
Those will be milled flat and I will get my friend to TIG weld it together so that I can mount 360 gearbox direct to G13B Gti engine.
I think progress from now will be very slow!
I think car is still registered as a Mini or they are made in factory as a new car.
Not sure to be honest.
I will look into it once I get it over to my place.
So after a trip to Glasgow, I picked up wheels from my mate.
I also bought rear disc roters, calipers, driveshafts and CV joints from MX-5 specialist.
I have chosen VW mk1 Golf wheels for my project. With this wheel, I can measure track width.
It is 1600mm from one edge the other.
I'm hoping to make my subframe narrower by 300mm or so.
I need to find out what is the measurement between 2 wheel arches as I will be increasing it.
I will be making rear wheel arches like bubble wheel arches for escort or something like that but not too wide.
