Side exit exhaust..!?
- Terrortech
Anyone gone anything I can kick up a fuss with!?
Re: Side exit exhaust..!?
Easy to make one, just cut off the exhaust and the right angle bend and either attach or weld a straight section of a similar diameter onto it so it pokes out the side.
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
- Terrortech
This may sound easy to you but I pretty shit at stuff like this! Is there anyone that makes them? Or will a dodgy garage be able to sort a brother out? Ow yeah is this going to reduce any power from my super die hard 1.7
Attack2001
A garage will be able to do it with a grinder and a welder
Depending on how low you are? you may need to cut a section out of the sill. And it wont reduce the power lets put it that way....
Have you ever run a 1.7 without a backbox... they are painfulAttack2001 wrote:A garage will be able to do it with a grinder and a welderDepending on how low you are? you may need to cut a section out of the sill. And it wont reduce the power lets put it that way....
- charlieog1243
Chris_C wrote:Have you ever run a 1.7 without a backbox... they are painfulAttack2001 wrote:A garage will be able to do it with a grinder and a welderDepending on how low you are? you may need to cut a section out of the sill. And it wont reduce the power lets put it that way....
Sounds just like mine
