What is this?
What is this?
Post by bogbasic »
Can someone tell me what this black box is and what the number on it should be for a 1988 360??
I want to get another one due to the box being broken at the base and need to know the right number - its been rubbed off!!
Many thanks, bogbasic.
5lab
Post by 5lab »
looks like the renix to me.
Swapsea-'89 360GLT-swapped!
Vario Si
Post by Vario Si »
Naa, isn't the renix the one on the left, not the one where the arrow is pointing to!?
Simon
5lab
Post by 5lab »
so it is. i've seen one before.. aux fuse box maybe? should say in yermanual
RandomHero
Post by RandomHero »
When this is going about a 340 variomatic (as you can see there is a mount for the 4-way vacuum valve) it's probably the tachorelais.
It could also be the relais for the wipers on an ealry model.
pettaw
Post by pettaw »
Its a special relay, that closes the idle fuel cut off valve, when the revs are above a certain level (about 1400) and the throttle is shut. Its a fuel saving device.
Eg, on cruise, lift off, the fuel cut off activates, stops sucking in excess fuel, until the revs drop off enough, then the carb effectively gets 'switched on' again.
Thing is, I've only ever seen it on 1.4s, I'll look in my 360 book in the morning.
Post by jtbo »
I do have that kind of box too.
huskyracer
Post by huskyracer »
I have one in mine, and the number is 209 472, but mines an 89 340 1.4. I had a quick scan through the haynes, but I cant find it so I have no Idea what it is supposed to do :oops:
pettaw
Post by pettaw »
Piccy from Volvo 1.4 green book, can't find an equiv in the B200 book, sorry.
Sorry its a large one, you'll have to click it and resize it to full size to read the print.
The equiv part number from V*d*s says 3209472 for B14 and 3209542 for the B200
Post by bogbasic »
That is very useful indeed. Many thanks for the replies. Cheers, bogbasic.
