I've checked the auto clutch gap and the shims that are currently in there. I measured the clearance gap as 1.2 and I have 2x1.5 (3mm) shims in there at the mo. According to my calculations I need a total of 2.2mm of shimmage in there for a 0.4mm gap? Some guidance says a gap of 2mm + or - 1mm is OK, but to make sure there is no clutch drag it's better to go for 0.4mm min?
If I've worked this out correctly, ideally I need 6x0.5mm shims + 3x1.2mm shims (or something close). If anyone could help I would be very grateful. I think I might be able to get them from Danny in Holland, but thought I'd ask on here first.
I'll make it worth your while
Thanks,
Soph
