front damper cartridge insert length
mat_91
Post by mat_91 »
as above rely has anybody go the lenght of it the bit i need measuring is the body of the damper
thanks mat
Evoman
Re: front damper cartridge insert length
Post by Evoman »
Im sorry, but can you write clearer please. Im pretty bad so tolerate it in in others, but your something else :P
You want the length of the strut tube? I could measure that if i was at home :?
mat_91
Post by mat_91 »
sorry i was in a rush earlier the measurement is the damper cartridge body length not the overall length nor the piston rod length just the body
the yellow bit in the picture if that makes sense
valman
Post by valman »
wish i could contribute, but then im looking for the same answer!
mat_91
Post by mat_91 »
ive measure the strut internally and got 340mm length and 49mm inside diameter
im going to nip to my local auto factors tomorrow and see if they will let me look through there book to see it throws up something that is smaller alot smaller
seannaayy
Post by seannaayy »
hey mate, did you get an answer for this? wanting to stiffen up the damping on the front of mine too.
mat_91
Post by mat_91 »
nar gave up in end but i was looking at corsa and stuff
but tbh my last thought was just about bunging the damper shaft in the lathe and turning it down
