low hanging exhaust? quick trick i just learnt
valman
Post by valman »
inb4 slowpoke if its already a common issue solver.
anyway, most 340 exhaust hang a bit too low dont they? especially if your car has been lowered.
well i sorted mine out by swapping how the back box hangs on the bracket that screws into the car chassis! i have no pics atm but what i did was remove the rubber, and simply switched the brackets round - put the back box hanger into the top rubber hole, and the bracket that hangs from the body of the car into the bottom hole. this has lifted my exhaust up by a good 2", and you can use the brackets to interlock them in place (again this will be all clear once i upload a pic) but anyway. i hope this has given food for thought for those that have exhaust issues - mine had to be rehanged every few days :lol:
hope that made some sense, if not you will jsut have to wait for a picture haha :)
charlieog1243
Re: low hanging exhaust? quick trick i just learnt
Post by charlieog1243 »
sounds good dude get some pics up! :)
Attack2001
Post by Attack2001 »
Definitely interested, MOAR PICS! :mrgreen: :mrgreen: :mrgreen:
Evoman
Post by Evoman »
Would the rubber not just rotate and then the body hanger would be at the top? :P
Logan360
Post by Logan360 »
That is exactly what i thought too. but i don't needs to worry mines is fine.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
Nimminz
Post by Nimminz »
Evoman wrote:Would the rubber not just rotate and then the body hanger would be at the top? :P
valman wrote: you can use the brackets to interlock them in place (again this will be all clear once i upload a pic)
Pictures should clear it up, i'm interested to see it.
valman
Post by valman »
yeah sorry guys forgot! ill go get one now, i managed to use the bracketry itself to interlock em in place - this has brought the back box up too, but my rear valance was already bent out of the way
Attack2001
my exahust hits absolutely everything, i need a pic of this asap to get mine raised up :roll:
Thanks :D :D
Thomas..............
littlemanrob
Post by littlemanrob »
i just solid mounted mine to the hanger and welded it on solved my problem but my car was to low anyway
Benfraser
Post by Benfraser »
I agree with thomas! Need a pic asap lol Exhaust is loooooow!
Ben....
valman
Post by valman »
my bad guys i've been well shit recently at doing things. basically where the bracket from the backbox goes to the hanger that screws to the body - flip em over and interlock in place. you might need to remove the bracket from the chassis put it into the bottom hole of the rubber and then kinda loop it under the backbox bracket? fuu no idea how to explain it really. i never got a picture of what i did but basically yeah, jsut flip it over, and use the brackets against themselves to keep it in place. easiest way is if you just jack up the car and have a look, then youll know exactly what i mean
