Anjo's 340Turbo: EFI conversion
Re: Anjo's Project Car: 1986 340GT Special, B14Turbo
Post by volvodspec »
some more work done, enjoy the pics :)
with the wooden blocks out of the way the whole cage was lowered 2,5" giving enough clearance to weld the top of the cage.
aluminium panels powdercoated:D
mounting tubes for the rear part of the cage
rear X in and the rear part of the cage allmost done, few more pipes to go
Nimminz
Post by Nimminz »
:shock:
Amazing mate, looking race car quality :)
Post by classicswede »
The cage is great ad very nice welding :D
Super-impressive as always. 8)
Post by MCHUDD »
Hi Anjo.
Fantastic work. Love this car.
sm4 sm4 sm4
cheers guys :D haven't had a chance to continue on this as i'm walking around with a cast around my arm due to a dislocated finger :|
jon-ovlov
Post by jon-ovlov »
Youch, sorry to hear bout the finger dude! But hey, those welds are gawwwwwjuss! 8)
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
volvodspec wrote: due to a dislocated finger :|
I take it we don not want to know how the finger acident came about :oops:
Soccer, had a great tackle and played the ball. Unfortunatly the opponent placed his foot on my hand
baron_matt
Post by baron_matt »
Have you thrown away all of the CVT stuff that you removed? :)
most of it went under my 343 actually :)
as a 343's CVT box doesn't have the ideal (quieter) weight/springs ratio as the later 340's have i swapped it for the box that was under this car, i did take it all apart first; checking/adjusting the mechanical gearlever, replaced a few seals and put it back together along with new belts/fresh oil and a powdercoated subframe
Post by trabitom99 »
volvodspec wrote:i did take it all apart first; checking/adjusting the mechanical gearlever, replaced a few seals and put it back together along with new belts/fresh oil and a powdercoated subframe
Like :-)
T.
mat_91
Post by mat_91 »
Looking good what did you make the cage out off
stainless steel tube :) i insisted on stainless for the looks, initial and welded finish and the difficulty for getting it done right, stainless is a metal that behaves rather strange when you work with it; everybody that talks about the weight vs chromoly tube should know that all the tube/plates/bolts etc will set me back 35kg on the total weight of the car, that's peanuts :D
