my volvo 360
Re: my volvo 360
Post by SteveP » 09 Dec 2012 10:04 pm
This'll be great with the 230 in :D
crazydan
Re: my volvo 360
Post by crazydan » 10 Dec 2012 09:43 pm
i hope so :lol:
engine is ready to go in waiting on a clutch :roll:
crazydan
Re: my volvo 360
Post by crazydan » 15 Dec 2012 01:20 pm
small update
still waiting for a clutch :roll: :roll:
but got a rover turbo throttle body converted to fit a volvo injection inlet manifold so fitted that and blanked off the injector holes
2.5 inch all the way through
and it mocked up with the lpg carb
and a random group a air filter i had luying about
then got onto the engine
started off with this
new end cover seal
crank and intermidiet cam seal
new water pump annd seals
swaped over sumps and pick up pipes
new timing belt+ tensioner
re fitted everything
quick pain on the block
and the rocker cover red ( with green volvo lettering ....... :lol: )
and here it is
u might see that the car has alot of lock.... ive made washers to space the bump stops in the rack all i need to do now is get the alignment set up a bit better and test it out
i also wire up my wide band lambda and started running llpg pipes but ill explain that more later on once i finished it :wink:
thats all for now
crazydan
Re: my volvo 360
Post by crazydan » 01 Jan 2013 01:45 pm
got it running last night on petrol (after removing the engine again due to fitting the flywheel 90* out :oops:
tomorrows job tidy it up abit and then swap inlets to my gas one :D
happy new year!
Re: my volvo 360
Post by SteveP » 01 Jan 2013 05:35 pm
Awesome! What injection system are you running? From the donor or carbed? Happy new year :)
crazydan
Re: my volvo 360
Post by crazydan » 01 Jan 2013 06:44 pm
carbed it was a b19a i think on a cd175 carb so im just removing the carb fitting a throttle body and a lpg carb and keep standard ignition
crazydan
Re: my volvo 360
Post by crazydan » 02 Jan 2013 09:24 pm
its running on gas verry happly :D :D
will get better pics on the weekend
Re: my volvo 360
Post by classicswede » 02 Jan 2013 10:16 pm
crazydan wrote:carbed it was a b19a i think on a cd175 carb so im just removing the carb fitting a throttle body and a lpg carb and keep standard ignition
Make sure you do not have any rev limiter or you will get a big bang if you hit it! :!: :!:
crazydan
Re: my volvo 360
Post by crazydan » 02 Jan 2013 10:18 pm
i wasnt sure if i should fit one or not :lol:
is this you talking from experience or? :lol: :lol:
Re: my volvo 360
Post by classicswede » 02 Jan 2013 10:21 pm
Over the year I've had a lot of folk come to me with smashed up air intakes, blown up manifolds, damaged mixers and vapourisers due to backfires from rev limitrs amoungst other things.
crazydan
Re: my volvo 360
Post by crazydan » 02 Jan 2013 10:28 pm
yeah quite the common thing with gas :roll:
ive got a non return valve (1.5") fitted so with a vacuum its shut but if it does flash back it just puts it out the valve did it once on me today whilst setting it up (my own fault turned the adjuster the rong way :oops: )but seemed to do the job spot on!
Re: my volvo 360
Post by classicswede » 02 Jan 2013 10:31 pm
You mean a pop off valve?
crazydan
Re: my volvo 360
Post by crazydan » 02 Jan 2013 10:51 pm
yeah think thats the proper name for them
crazydan
Re: my volvo 360
Post by crazydan » 15 Jan 2013 08:04 pm
ok update
car has been running for the past week spot on (except the gas vaporiser going so now back on petrol)
think the cars going to get used for autotest etc now so my mate ( who i sold the bike carbs to) is going in halfers for the car with me
so bike carbs are getting fitted again :D
also fitted my 3" dished wheel love it :D
Re: my volvo 360
Post by SteveP » 20 Jan 2013 03:28 pm
Pics or it didn't happen :P :lol:
