help!!! stuck and not sure what im doing
thejackal01
i have a volvo 340 1.4 vario 1986, and i am still having problems with the engine reving its nuts off its now doing uto 4000rpm at 30-35 and drink juice.
i have just noticed from the ing coil there are 3 plugs. one plug on the end with red, white and black wires are not connected to anything. the white wire is just hangimng there and the other two taped up ?? should these go somewhere.
and not sure what the white box on the boittom of the engine bay is too. there is a pipe from the vac pump leading to this if that means anything to someone.
sorry to be vague, but not worked on varios before and cant find a manual for this car.
any help would be great and to identify these items. thanks guys
Re: help!!! stuck and not sure what im doing
Can you get a picture?
thejackal01
not got anyway of uploading pics on here unfortunately.
im not very technically minded where computers are concerned
- volvodspec
the plug with the red/black/white wire is the Renix C-plug, this is for retarding the ignition if you have a catalyst converter. is not the cause for your engine doing 4000rpm
the white box is the declutch servo, it is operated in D and R if you press the button on top of the gear lever, it switches vacuum to the declutch piston (wich roughly acts as a clutchpedal on a manual car) this pulls the clutch a bit free so that you can change gears when you have the engine running above idle (when choke is applied)
you need to go through this http://www.volvo300mania.com/forum-uk/v ... =6&t=12314 to get it sorted, it is not hard and the vario definatly isn't rocket science but it depends on quite a few thingies to work properly
thejackal01
ahh right..... cheers for that information, that is very helpfull. was not sure what these were.
excellent stuff. will be going through the info in the morning to test this.
will post what i find. thanks again...
I did post that link to the CVT Diagnostic Manual in another one of thejackal01's threads: http://www.volvo300mania.com/forum-uk/v ... =2&t=14613volvodspec wrote:you need to go through this http://www.volvo300mania.com/forum-uk/v ... =6&t=12314 to get it sorted
...three days ago.
- volvodspec
haha, i didn't notice that thread
^^^^ hehe, nor did the OP.
thejackal01
no i didnt, i couldnt find the thread from before. i am useless with computers ...doh!
thejackal01
this is what i found so far. the vacuum is hardly sucking at either A or B, less on B really.
i checked the connections on the block connector, found pin 6, shows off the scale. when the 3 switches are used the ohms drop to 0ohms, but when released off the scale again??
does this look like i have a bigger problem than first thought?? any ideas guys
thejackal01
RIGHT I HAVE BEEN THROUGH THE MANUAL AGAIN, AND GOT A LITTLE HELP THIS TIME. THE DIODE IN THE EMV IS BROKEN IN 2 PARTS, THE LITTLE RUBBERS INSIDE HAVE SPLIT AND NO SUCKING ON THIS WHEN DOING ALL THE TESTS. GOING THROUGH THE CARS HISTORY IT WAS SUPPOSED TO HAVE THIS REPLACED LAST YEAR, BUT LOOKS LIKE THEY TOOK IT APART, LOOKED AND THOUGHT, HHMMMMMMM, PUT IT BACK TO GETHER BEST AS WE CAN.
WHERE CAN I GET A REBUILD KIT FOR THIS AND CAN ANYINE TELL ME WHAT SIZE DIODE I NEED PLEASE. SORRY BUT COMP STUCK ON CAPS LOCK.
THANKS GUYS
THANKS GUYS
Please buy a new keyboard then. They are quite cheap.thejackal01 wrote: SORRY BUT COMP STUCK ON CAPS LOCK.
Got your PM. Will reply after dinner. Only just back in....
volvomania
You can contact Macplaxton (he is in the UK) for the proper overhaul kit. It contains the diode and all the rubber bits inside.
No need to worry how to overhaul it, there is a comprehensive "Ikea-style" manual included.
If he is out of stock, you can contact as I also hold stock. Postage will be more expensive however as I am in Belgium.
PMs are in progress RJ. Got stock in hand here.
volvomania
Can't help promoting youmacplaxton wrote:PMs are in progress RJ. Got stock in hand here.
