Hello
PISTONMELTER5
Hello
Post by PISTONMELTER5 » 19 Oct 2012 07:55 pm
Just joined up there as i should hopefully be a volvo owner come the end of the week!
planning on taking a look at this tomorrow with every intention of buying it, should be able to knock him down a few quid too :)
http://cars.donedeal.ie/for-sale/vintagecars/3973336
Will be using it as a daily as my fiesta is gettin wrecked on the shitty roads, especially as its just back on the road!
Sorry if this isnt the right section for questions i havnt really had a look around yet as i said id throw up an intro first!
what are the 1.7 engines like reliability wise? economy?
tbh i dont even know what they are like to go power wise so would be great if someone could give me some insight into them as tbh i have never had anything to do with em or either have my mates so its a whole new ball game for me :oops:
look forward to seeing some of the site :)
Re: Hello
Post by MCHUDD » 20 Oct 2012 01:25 pm
Hi mate and welcome.
What part of ireland are you in?
sm4 sm4 sm4
PISTONMELTER5
Re: Hello
Post by PISTONMELTER5 » 20 Oct 2012 02:11 pm
Co.mayo buddy :)
charlieog1243
Re: Hello
Post by charlieog1243 » 28 Oct 2012 02:23 pm
welcome dude it looks pretty cool there reliable i reckon i never really had a problem with both my 1.7s get the diff welded and just have some fun!
PISTONMELTER5
Re: Hello
Post by PISTONMELTER5 » 06 Nov 2012 12:02 am
Thats good to hear! Hopefully picking it up on friday :D
Whats a welded diff like being used daily in one of these? A few of my mates has had cars with them welded and it does vary from car to car in terms of usability i find :?
Apart from coilovers what are my options for lowering the front on the standard shocks?
Any advice would be appreciated as im spanking new to all things volvo! :)
tim-andre
Re: Hello
Post by tim-andre » 06 Nov 2012 06:08 pm
lowering blocks on the rear, cut springs in the front? :D
or you can get the leafs lowered by a specialist, and buy some lowering springs to the front from dai :)
lowering blocks on the rear isnt that bad of an idea, if you dont over do it, so the bottom of the damper hits the road or something and get bent..
War isnt about who is right, but who is left
Re: Hello
Post by Speedy88 » 09 Nov 2012 08:48 am
Welded diffs are ok in these cars, I'm running super grippy toyo proxies on the rear and although not ideal (I wish I had cheaper tyres to throw on... but these were all I had in the shed) I'm still able to use the car comfortably. And I have to parallel park!
ali3404994
Re: Hello
Post by ali3404994 » 26 Feb 2013 03:23 am
Right, sorry to drag up an old thread but here seems like a decent place to ask. Basically, is it much harder or cause any other problems by welding the diff without taking it out the car? Do people usually take them out to weld up or just take off the back plate, drain the diff/box and making sure you clean out any mess afterwards?
Re: Hello
Post by Speedy88 » 26 Feb 2013 08:34 am
The problem is the rear axle gets in the way of the backplate, not really enough room to fit a welding torch in.
In a 340 you could disconnect the prop, undo the diff mounts and angle the diff downwards for better access, but you risk damaging the front mounts.
In a 360 you don't really have a choice and it's going to have to come out (undoing mounts and angling down will bend the torque tube and put strain on the engine).
Basically the best method for both cars is to take the diff/gearbox out together, take off the back plate, spray some ethanol cleaner in there, burn it all off when done, weld the diff.
940s are a lot easier, you can just do them on the car sm4
Re: Hello
Post by classicswede » 26 Feb 2013 09:35 am
You can weld the diff in situ, I've done it a few times and all have held perfectly. I did them on ramp and with the pit jack just lift to give you the clearance. I dont think you could do it on a 2 post
Re: Hello
Post by Speedy88 » 26 Feb 2013 10:13 am
Hmm, maybe on a ramp. I'm assuming the poster doesn't have access to one though :wink:
Re: Hello
Post by classicswede » 26 Feb 2013 10:53 am
You could probably do it with some car ramps or raise the car on suitable blocks.
Re: Hello
Post by Chris_C » 26 Feb 2013 11:33 am
Why not drop the axle? 5 minute job ;)
ali3404994
Re: Hello
Post by ali3404994 » 26 Feb 2013 03:14 pm
Thanks for the immediate feedback everyone. It's actually someone to weld it that I'm lacking but I do have access to lifts. I have no welding experience myself which is why I'm trying to see what the options are for someone I find to do it. It doesn't sound like too much of an issue though so consider me suitably helped here. Expect to see me rearing my head elsewhere at some point, thanks guys sm4
