Adam2012
Post
by Adam2012 » 09 Apr 2013 10:25 am
I have the seat belts from my 340 but they have not been in the car for sometime. I have not yet tried to re-install them because they are locked meaning the belts do not pull out from the mechanism however, they do retract but then it just make the belt smaller. So my question is, can they be fixed and get them back to working order. Any advice would be much appreciated.
It is for all seat belts front and back.
Thanks
Logan360
Post
by Logan360 » 09 Apr 2013 11:06 am
Have you tried bombing the mechanism with crc or wd40 type solvent? brake cleaner?
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
95 Nissan Pulsar
Owned
Adam2012
Post
by Adam2012 » 09 Apr 2013 11:17 am
Would I have to remove the plastic or just spray it all over
Post
by Chris_C » 09 Apr 2013 12:54 pm
Neither... they have to be held dead vertical otherwise the inertia mechanism won't let any belt out. Try holding them at the same angle they are in the car (or bolting them in) then seeing if the same thing happens.
CBA
Post
by CBA » 09 Apr 2013 03:09 pm
thats what I was goona say, they have to be vertical, they are meant to lock if the car goes upside down, they lock round corners, on angles.. anything but dead still and dead vertical and they should lock.
Adam2012
Post
by Adam2012 » 09 Apr 2013 04:36 pm
Thanks for all your help, however i will have to try(I'm going to put them back in the car to get the correct position) this later as I simply dont have the time today but i will let you know how it goes thanks
Post
by Hell Driver » 09 Apr 2013 05:01 pm
As Chris said, very tricky to get them to pull out when not in the car, you can do it but it's easier to put them in or at least hold them in position in the car to get the angle right.
343 DL (W 80)
R.I.P. 77 343 DL vario
Adam2012
Post
by Adam2012 » 11 Apr 2013 09:58 am
Sorry for the late reply guys, I did manage to try them in the car and no luck so ill just get some new ones from a volvo 340 being broken
Thanks anyway
