Anjo's 340Turbo: EFI conversion
Re: Anjo's Project Car: 1986 340GT Special, B14Turbo
Post by volvodspec » 06 Jan 2013 10:58 pm
update time :D rear cage is very near to completion, i've put most of the interior back in and got the dash back in (don't ask how hahaha)
i'll start the new dash of alloy plate and stainless steel bits in the spring, first it needs a new MOT in a few weeks so i've been only busy getting the car running again
so also put the stock fuel tank back under, with the filler cap in the trunk as the alloy plate's in the rear block the original cap
harnesses mounted
and it runs again :)
http://www.youtube.com/watch?v=_GsWjS01VH8
the christmas holiday i've been busy clearing out my second storage, after a week i finally was able to get the car inside and with just enough room to work on it if the weather is bad
took it for a small shakedown and i found that the knobs of the window mechanism were rattling, so i've modified them with a delrin bearing and a new fixing, the mounting to the window frame has also been altered; from a hex bolt with a 3D ring to a stainless ring with a flathead screw
also shortened the doorhandles, made the mounting shorter so they feel much more solid (previously you were able to wobble them up and down a little), still not 100% happy with them, will make something new once the front cage (doorcrosses) are in
finally a wash and it went back into the storage. productive weekend :D
next weekend to Germany for a snowboardingweekend and after that; bring on the MOT :D it's done 460km since last year so it should fly through with ease
Post by volvodspec » 30 Mar 2013 12:02 pm
started with the frames for the fueltank and swirlpot, then got the flue and still recovering so unfortunatly everything stalled after this.. more soon
Re: Anjo's 340Turbo: EFI conversion
Post by volvodspec » 01 Jun 2013 09:12 am
car was allready in a storage unit but i've been busy getting that storage unit to a level where there would be a efficient storage and a small workspace at the same time, i still do a lot of stuff next to the house but this way i don't need to worry about tools laying around and stuff and if i need to fabricate something it simply is a 250m walk to the workshop
finally started with the EFI conversion, first i removed most of the carburator related stuff
then tried on the new manifold, needs a tiny amount of trimming but nearly there :D
Post by volvodspec » 02 Jun 2013 09:54 pm
engine bay stripped out a bit further
and this car is also getting an LSD :wink:
Post by classicswede » 02 Jun 2013 10:05 pm
You must be trippin :lol:
LSD is a great idea for this car. What ECU are you going to use with the fuel injection system?
Post by volvodspec » 03 Jun 2013 07:18 pm
KMS , it will control both fuel and ignition (DIS coil) :D
Post by SteveP » 03 Jun 2013 08:32 pm
Love the fact you're going fuel injection, I bet you'll be able to get a load more power out of it and much more safely :)
Post by volvodspec » 05 Jul 2013 08:48 pm
since it will get a DIS coil i no longer need the distrubuter, as the shaft potentially is a nice place for securing wiring etc i intend to keep it in place for now but it will lose the dizzy cap offcourse so i made a new cover
also converted the throttle operation from cable downward to the rear,
made a bracket for the fuel pressure regulator
more soon, i intend to enjoy the good weather the following weeks :wink:
Post by jtbo » 05 Jul 2013 09:26 pm
I just found out reason why my projects progress so slowly, your wirebrush is exactly like mine, but your has green handle, mine has red handle, of course that must be reason why my projects are at full stop or almost :lol:
Your car is bit insane, mad, crazy, lot of very beautiful work 340pw
Post by volvodspec » 15 Jul 2013 10:43 pm
cheers Jani :D
here's the fuel pressure regulator on the engine;
time for some plumbing..
found out i'm short on couplings, ouch... another order made; waiting for them to arrive so i can get started on making all the hoses.
i'm also redoing the oilfeed for the turbo, it'll be much shorter and withoud the R5's adapter. only problem is that the adapter had a sensor in it aswell, that had to move too so i've decided to run a second sandwichplate, one for the oil cooler and another one for the sensors
then on with the lh side, making a bracket for the KMS DIS-coil and aquamist pump; as the car isn't stored around the corner of our garage i started with a quick sketch in CAD
cutting a piece of 0,8mm brushed stainless steel
bending
making radius edges
nerly there..
made threaded mounting points on the lathe
welded
and fitted the coil and pump
and in the car with vibrating dampers under the plate; fits spot on :D
that'll be my spare time for the week; gonna enjoy the good weather now the next few days sm37
Post by Chris_C » 16 Jul 2013 11:46 am
Now that's just pretty! Lovely job Anjo!
'89(F) 340 GL F7R (ex B172k) - Fake -> SBKV 300 Runner Up 08, 12 - NASLR Time 15.7secs
'03 S60 D5 SE, '91 (J) MX5
'91(H) 340 GL B14.4E - Kar; '88(F) 360 GLT B200E - Jet -> BKV 300 Runner Up 09; '89(G) 360 GLT B200E - Beast
Post by volvodspec » 26 Jul 2013 05:13 pm
also modified my oil separator, it wasn't efficient enough so i enlargened the fittings to ø22mm and the oil drain wasn't the lowest point so a bit of oil and condensed water was stuck in the resevoir
first off with the old mounting plate
new plate + hose connections
welded
and in the car
Post by volvodspec » 27 Jul 2013 09:42 pm
another tank, for the windscreen washer :mrgreen:
and widened the rear inner frame for placing of the washer tank and aquamist resevoir
mac
Post by mac » 28 Jul 2013 11:00 am
All this must be giving some "purists" that we know multiple heart attacks!
As ever top class work Anjo, more impressive by the day - an absolute credit to you!
Mac.
87 3door DL 1.4 58k - 88 3door DL 146k - 88 5door Redline 1.7 52k - 12 XC70 SELux AWD D5 22k
Post by volvodspec » 29 Jul 2013 06:01 pm
Cheers Mac :D
today i started on the aquamist tank
i started with calculating and cutting a few plates to form the lid and bottom
tacking and welding
and machining :mrgreen:
for the filler cap and pump connection
connections for the fluid indicator
almost done
made a lid :D
windscreen washer bottle in the same style;
more tomorrow :)
