Just wondered what rubber bushes are still easily available in the UK for the front end as I have a feeling I need to replace some of them. Mainly looking at the anti roll bar rear bushes, stabiliser link bar bushes (straight type that goes on ring fitting of anti roll bar) and radius arm bushes. May also think about doing the wishbone bushes while i'm at it but does depend on what is available and what needs changing.
I know poly bushes are better but just trying to keep costs down a bit, but if I do have to get poly does anyone know the cheapest place for them. I know Dai makes some poly bushes, not sure which ones, but are all these items available in rubber or will I have to get poly and any idea on price?
You will be VERY lucky if Volvo can supply anything. - middle of last year the only part available from
the list below was 3296121 (and I have 8 in stock myself)
Front end bushes comprise:-
Reaction rod large bush (x2 req'd) pt.no.3296121
Reaction rod small bush (x2 req'd) pt.no.3100899
Wishbone inner bush (x2req'd) pt.no.3290010
ARB mount -85 (x2 req'd) pt.no.3260650
ARB mount 86- (x2 req'd) pt.no.3208464
ARB link lower bush (x2 req'd) pt.no.3291540 (ARB link to w/bone)
ARB link upper bush (x2 req'd) pt.no.3101159 (ARB link to w/bone)
Reaction rod bush kit (both sides) available from "Superflex" @ £31.50 or Dai @ £20.00
Wishbone inner kit (both sides) available from "Superflex" @ £32.40 or Dai @ £30.00
ARB mounting bushes (x2) available from Dai @ £12.00
ARB link bushes/link/washers/nuts (both sides) available from Dai @ £25.00
(prices checked on relevant w/sites today)
Hope this helps - Mac
When I last tried to order rubber bushes from the dealer they were nla. Look like poly is the only answer or wast money on cheap reproduction rubber ones.
Hi guys, can anyone of you help me with a information? I need the code, producer or some kind of code for front bushes (the ones that are passing thru the suspension arm, rubber +metal on the interior). 360 GLT, b200 engine if matters. Thank you
the early bird gets the worm
