BHX engine unhappy
S10NPH
BHX engine unhappy
Post by S10NPH »
BHX, my 1979 343, has been running fairly poorly recently. I thought I would share the symptoms here to see if there is a consensus as to what could be wrong.
Since I got it, BHX has always been slightly hesitant on the accelerator, particularly until fully warmed up. The engine has also always made a slight rough note on acceleration which I had thought might be pinking, but Mac's experienced ears disagreed. Anyway, it was essentially fine and idled really sweetly, so I did nothing much about it.
You might remember that last summer, the condenser failed and the points went bang. When the AA man tried to play around with it, he took the air filter off the carb and revved the car quite a bit; it sounded extremely rough, like a motorcycle engine. I've never heard it sound so awful!
Anyway, I replaced the points, condenser and coil at that time, and the car was working again, although it was not running as sweetly as it was before the bang incident. It still has hesitation on the throttle, it 'kangaroos' a little when doing a constant speed, and engine braking comes in too quickly when releasing the throttle. Incidentally, the points gap is correct. On acceleration, the engine sounds very rough (it has brand new oil - no change), and on idling in traffic it sounds just like a diesel, with a constant tick.
The other thing to note is that the timing was off, and Mac adjusted it to be correct when he was over last year. If anything, it has been much worse since that!
Yesterday, I took out a spark plug, which was very oily. The plugs were new last year as I recall.
I checked the water reservoir, and it has a very minor shimmer on the top, and is quite thick on my finger:
The oil filler cap has the tiniest bit of 'mayonnaise' on it, but nothing major:
I don't suspect full OMGHGF as the car still has plenty of power and there's no white smoke, but perhaps something else is leaking.
Anyway, I'd be grateful for ideas. I'd like to return it to running sweetly again.
Re: BHX engine unhappy
Post by bogbasic »
Hello, have you tried tightening the bolts around where the carburettor sits on the inlet manifold and/or a bit of silicone sealant around there? I'll keep thinking... Does it have a vacuum advance mechanism? If so, that might be leaking....
mac
Post by mac »
Plainly something is not right.
The plug is definitely "oiled" and whilst some oil will always find its way into the combustion chamber the pic shows evidence of either oil leakage across the head deck, or completely knackered valve stem oil seals.
Furthermore there should be NO signs of oil in the coolant reservoir - the pic suggests at least a small leak allowing oil into the water.
Condenser failure is not uncommon with modern "quality" ignition components and that in itself could account for points failure. (No excuse for the AA to rev the Bol locks off it - but not surprising). The poor running could be simply that I got the timing wrong (it was with a quality SUN timing light) but it's possible I simply made a mistake) That wouldn't explain the "diesel" noise, or the oil in the water, or the oil on the plugs (weak ignition will give wet plugs but from fuel not oil)
The tick may simply be a slack tappet, but why should it change? Again it's possible that one ore more valves may be pocketing but that would close up the gaps and reduce noise.
It is looking likely that "all is not well in the state of Cleon" and I suspect that "all may not be well" with the state of the head gasket. It would do no harm to pull the head and investigate (after a compression check) the engine could only benefit from a valve job anyway.
I'm not suggesting a massive HG failure but it certainly looks like oil is getting into the chambers and the running trouble sounds like a leak between cylinders to me.
Mac.
Post by bogbasic »
Yes, sorry I couldn't see the oil in the water from the phone..... it looks like head gasketitis now that I can see it better.....
Yup, it certainly looks like it could be HGF, but in a pretty mild and undramatic way! How old is the coolant - it couldn't be someone using the same funnel to put oil in the car as the water?! I doubt it as I'd imagine you've probably changed both anyway, but I've seen it before on old stuff!
V6 Man
Post by V6 Man »
It doesn't have to be HGF, it could be a cracked head - it's not unknown.
S10NPH
Post by S10NPH »
Yes, there was a cracked head on the 1981 car in Ely, although I'm told that had become un-drivable pretty quickly as a result.
Steve, I am struggling to remember whether I have changed the coolant on this car. It's the problem with having a bad memory and too many cars. I have now started to keep a service log so that I can note when I do things on all the cars. It is therefore perfectly possible that the coolant is very old.
Saying all that, I drove it today and it was fine really, just a little roughness on the throttle and the diesely/tappety sound on idle. It has plenty of power, doesn't seem to smoke.
I think I will source some gaskets, and set aside some time to take the head off to see what I can spot. I have never done it before, but it doesn't seem all that complicated (I bet I will regret saying that).
Just make sure you follow green book procedure when taken the head off and get the correct Volvo Special "don't let the bloody liners move no matter what I do" tool (Some M12 washers from memory, but check!)
Or leave the push rods on Pettaws bonnet when you drive off to get said special tool and have to drive around Rickmansworth collecting them from the corners in the road when they rolled off.
mac
Post by mac »
I have two sets of the "don't let the bloody liners move" tools, (and gaskets in stock for that matter).
The job is well within your ability. - just let me know what you need Siôn.
Mac
Post by macplaxton »
Chris_C wrote:and get the correct Volvo Special "don't let the bloody liners move no matter what I do" tool (Some M12 washers from memory, but check!)
Pah! Just do something with all those odd-sized sockets in the set and use the head bolts.
mac
Post by mac »
How delightfully "Irish" - I see the culture rubbing off!
volvomania
Post by volvomania »
If it was truly Irish he would have used full glasses of Gxxxxxxss :lol:
Cracked heads are certainly not uncommon.
Post by classicswede »
If it turns out you need the head I have if yours has cracked I don't mind doing a swap.
Before whipping the head off.. and not knowing the state of the coolant, I'd be tempted to change the coolant and do a compression check :)
mac
Post by mac »
mac wrote:Plainly something is not right.
Mac.
M
