F7p conversion
Scrapman
F7p conversion
Post by Scrapman » 07 May 2014 06:17 pm
I have got a 340 with f7p engine conversion could anybody help me on how to adjust idle speed please
Re: F7p conversion
Post by classicswede » 08 May 2014 10:55 am
what fuel system is it running?
Scrapman
Re: F7p conversion
Post by Scrapman » 08 May 2014 05:03 pm
The standard injection system with ecu
Alex Laidlaw
Re: F7p conversion
Post by Alex Laidlaw » 10 May 2014 07:06 pm
There's no adjustment of idle speed, it should idle correctly if everything is present and correct. What is it actually doing?
Scrapman
Re: F7p conversion
Post by Scrapman » 12 May 2014 06:21 pm
It idles fast on tickover
Re: F7p conversion
Post by Chris_C » 13 May 2014 01:15 pm
Could be a number of things. First thing I would check is that the idle air control valve takes it's air from the main feed to the throttle body, not a separate filter. It has to have some vacuum on that feed.
Scrapman
Re: F7p conversion
Post by Scrapman » 13 May 2014 07:47 pm
Ok thanks will try that first
driftking89
Re: F7p conversion
Post by driftking89 » 23 Oct 2014 11:57 pm
does it drop below what you state is fast idle if it does then while engine is running pull one plug off at a time round the throttle housing if there is a change in engine behaviour this means that the sensor is working so try that its quicker
Volvo 340 2.0 Supercharged drift wagon
Volvo 850R 2.3 Turbo
Toyota Celica 2.0 Import
