Restoring To Standard 360 GLE
Hi all,
I am having trouble to find this thing.. anyone have it in good condition? Thanks
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
01 Volvo S40 Phase 2 Turbo
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
volvomania
Is it the actual dash, the plastic surround that houses the switches or just the instrumentcluster you want?
It's the plastic sounding the meter, the instrument and the light knob.
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
volvomania
That should be quite easy to find in the UK (RHD).
On the continent they are all different (LHD) and unuseable for you.
Why don't you put a posting in the "Volvo 300 series: demand" section?
I am sure that postage to Malaysia will be more expensive than the part.
I will have one available next week off my JIG car but as RJ says postage will certainly cost more than the part
Ok..thanks mate, by the way can you classicswede post the picture if you have it? it think it's weight is less than 500 gram..can you find out the the total postage ? and if you have the bracket for the rear bumper can you post it too?
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
is it the L shaped rear bumper brackets you need?
saloon or hatch? different bumper mounts.
Classic swede: No it's the plastic that is screwed to the body and you just slide the rear bumper to it so that the bumper wont hang..ya know what i'm sayin..
there are two pieces. It's almost the same shape as front bumper, only slightly bigger.. i got 1 member post it to me earlier this year..i think it's mchudd or something. I'll try to post the pic.
Volare Volvo 360!!
Volare Volvo 360!!
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Here is the pic
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
I have everything you need, in good condition too. The dash surround has a crack at the far lower left but it is not visible with the cluster in place. And I have a pair of rear bumper plastic mounts too.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
Thanks Logan, can you possibly post the picture of the dash. just to make sure it's the right thingLogan360 wrote:I have everything you need, in good condition too. The dash surround has a crack at the far lower left but it is not visible with the cluster in place. And I have a pair of rear bumper plastic mounts too.
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Pm me your email as I can't upload photos to the forum.
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
pm to you just now.
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
Hi again,
I have trouble to start the car could it be the fuel relay? i checked the fuel pump it's running perfect. At first i thought it was the pump because when it's in ignition there were no noise coming from the pump. I test it on my car battery, the motor spins well, i got a replacement relay from 240 is it compatible? before i remove the pump i also checked the hose from the pump to fuel filter on the engine bay but there were no fuel coming out. One question does my model (360 GLE) have two fuel pump? as i checked there is only one on the bottom of the car. When i checked under the passenger sit, there is a round cap and after i remove it there were no pump only float. Need advice.. and may i know where is the fuel pump relay located, here is the picture..
- Attachments
OWN:
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
89 Volvo 360 GLE
89 Volvo 360 GL
89 Volvo 360 GLS
Owned:
84 Volvo 240 GL
