How do I replace the oil in my front shocks to EP90 diff oil to stiffen them up..
Sorry for the some what stupid question.
Thanks in advance for any replies.
Wow thank you for the informationthododd wrote:Youll need to start by removing the strut;
so jack the car up and pop it on stands
Wheels off
Undo; ball joint, steering arm, top mount and take the caliper off the brake disk.
Remove the strut from the car and then having compressed the springs, you can undo the damper top nut and remove the top mounts, bearing, upper spring seat and springs from the strut assy.
When you undo the damper retaining nut youll be presented with either of the below dampers
The one on the right is a cartridge/insert sealed unit so youll need a new plan if youve got these
The stuff on the left is what you want. When you remove the damper retaining nut the oil in the system can escape (this will be your first indication) so once youve taken the assembly from the strut body and drained the remaining oil, put the dif oil back in and rebuild the strut in the reverse of the above procedure.
Remember what order everything comes off the damper spindle and be careful with compressed spring ... best of luck, let us know how you get on. We always like pictures
