Vehicle Speed Sensors
Re: Vehicle Speed Sensors
You'd NEVER get 40mpg out of a 360 injection. Scraping 30mpg is hard enough and the three that I've owned have all been the same LH2.4 is far better than the crappy LE Jet fitted to 360 injections. Carbed 360's are a lot better on fuel, under most situations (eg. except from cold start with choke, probably).
Back on topic, these 3d printed holders are really cool
I think you're right, the difference in LH2.4 is mainly the idle mode which is very lean (or close to), thats what allows me to get 40mpg using pulse and glide in idle. Probably not much benefit for normal driving though. Might work on B200F.
So, firstly an apology to Ride_On. It's taken me a ChrisStandardTimePeriod to get to this.
There are only a few pictures as I didn't have my camera nearby and had to use my phone.
First job was to take the 400 series dash and work out what the power supply section was doing to the standard sensor.
Voltage is supplied via the on dash voltage reg (10 V, datasheet and measured, less than 10 mV ripple measured) and supplied to the Vehicle Speed Sensor (VSS) with a Zener (unidentified, mine is crimped in a way I can't see the last letter(s)). Measured voltage at the Zener is again 10 V, with less than 10 mV ripple.
First test was on the original 400 series sensor. 3 - 4 mA current draw measured, Vout at the sig line of the sensor was clean 0 - 10 V square wave with 4 periods over a 360 deg rotation of the speedo head. These periods as far as could be measured were of equal mark space ratio.
Scope was set to storage mode, an arbitrary time window chosen and the speedo head spun at a representative speed as would be seen during normal use. Output waveform was crisp with negligible rise and fall times.
Second test was on Ride_On's sensor. Firstly, the 3D print is of good quality and the fit to the 400 dash was very good. No modification in any respect and screw holes aligned perfectly.
As scope was set to storage mode and so tests would be equivalent, the representative RPM test was conducted. A snag was noted at this point, the rise time of the sensor was significantly different to that of the 400 series original.
I have used the family of sensors that Ride_On is using before and hadn't seen this behavior previously. As can be seen in the photo above, the VSS was supplied with an LED attached to ease testing. It is an ultrabright white LED, total system draw was 19 mA with this attached so on a hunch I removed the LED and repeated the test.
Rise time issue solved. Mark space difference to the original sensor is down to the consistency in the operator spinning the speedo head, not the sensor itself.
All other tests conducted showed clean 0 - 10 V output square wave, 4 periods over 360 degree rotation of speedo head, these periods as far as could be measured were of equal mark space ratio. Current draw of sensor again read 4 mA.
Conclusion:
If Fake was running, I'd have no hesitation of running one of these sensors for a full road test. As far as I can test, they are identical in performance to the original unit.
Ride_On, well done chap. Just sorry again that it's taken me so long!
Conclusion:
Well done, sir.
Nice equipment and good testing! The 4 mA choice was a bit of a guess to get a decent signal to noise without drawing alot of current. I'm pleased the original designer chose the same. I presume this is unloaded without the computer connected. LED was just what was lying around and mainly so basic function can be checked while confirming mechanical accuracy. The 20mA was within the ability of the sensor, the rise time maybe a function of the resistor in the 440 circuit, but as you say the LED is just temporary.
I didn't realise the 440 would be working on 10V, I think the 940 is working on a 12v signal, I must recheck that, but it should not be critical if the computer input is designed sensibly, and it should be happy with either supply voltage.
Did you confirm the needle is still moving ok?
Indeed, just the scope probe. I would imagine the ECU itself was a high impedance input so should be relatively similar?Ride_on wrote:I presume this is unloaded without the computer connected.
Fake is working on 12V un reg'd, which likely explains some of the issues I've previously seen with my speed sensor. The fact I've got unsheilded cables near the HT side doesn't help either, it's on the list of things to fix.Ride_on wrote:I didn't realise the 440 would be working on 10V, I think the 940 is working on a 12v signal, I must recheck that, but it should not be critical if the computer input is designed sensibly, and it should be happy with either supply voltage.
Yup, it's all still working fineRide_on wrote:Did you confirm the needle is still moving ok?
I don't know how many prototypes you went through, but the one you sent me just felt like a clean well engineered solution. I was sad (in an engineering "awwww bugger" way) when I saw the rise time issue because it had all seen so good up until then, but then happy again as soon as I realised it was a red herring and wouldn't occur in the real world and likely that the original would have done the same thing.
I really hope all the car enthusiasts that have cars using this sensor (and there really are lots, VDO put it in a lot of things at the time) find the work you have put in and benefit from it. The only thing different to the original is the fact you have to solder the wires from this sensor to the flexi PCB somehow, but it has the ability of keeping cars running and being electrical is one of the parts that car people seem to be naturally dubious of.
I think it was the 2nd 3D print, just to correct some mistakes. The original sensor position was in the wrong place. Electronics was designed and unchanged but I was not sure how the LH2.4 is designed. There maybe a pot divider at the ECU which will draw some current, but doesn't need much. I check it out soon.
I made a 3rd after that to adjust the height, yours was cut down a little for clearance. Incidently how does the magnetic sensor height compare with the original? ie the top interface surface when the screw holes are to the magnetic sensor surface.
I only got the car back a few weeks ago and killed myself last week doing the clutch in a 12hr marathon. Got hols comming up so will install mine soon.
At the end of the day the main benefit is to have a proven holder, I plan on sharing it on TinkerCAD so anyone can load it up, copy+modify, print to your local print guy etc.
Just to update this, have installed and used mine, but not sure it is making any difference. I still have some minor issues with high idle when cold, maybe to do with the throttle body adjustment.
Anyway holder is public on Tinkercad, select, print and pay if you want one. I don't know if solid printing is necessary, probably work fine with their normal percentage, as there is not much intermediate volume.
https://www.tinkercad.com/things/d7KWyZdxanN
Epic work.
So another update.
Car has been working well enough with the speed sensor, but through a minor error I drove the car without the speedo working (cable not engaged properly).
On applying full power the ECU decided to set the idle to about 1800rpm, and nothing would change it other than switching off/on.
I though this might be an corruption issue due to low voltage or EMC interference from the ignition or something but on research it seems this is a symptom of having no speed detected when full power is detected. Noone seems to understand why this is, possibly limp home thing, and there maybe an error code. But reinstating the speedo drive cable fixed it anyway.
So this at least is a reason to have the VSS installed.
