360 R-Sport in the lanes
Post by foggyjames » 04 Aug 2005 01:25 am
Enjoy...I'm (obviously) babying it until about 25s in. From memory, that wasn't WOT...not that it makes a notable difference!
http://www.foggyjames.co.uk/inbox/360rs.wmv
James[/url]
5lab
Post by 5lab » 04 Aug 2005 07:39 am
i hate roads like that - gimme a b road any day :P
Swapsea-'89 360GLT-swapped!
Post by foggyjames » 04 Aug 2005 01:38 pm
True...maybe I'll film one of those when I've got a tripod :-P
petefarrell360
Post by petefarrell360 » 04 Aug 2005 06:52 pm
Love that throaty sound, very nice indeed, it sounded great when you let it rip when you called by that day, makes people look, then go, hang on........ that's a Volvo!
Post by SteveP » 04 Aug 2005 06:59 pm
Damn it does sound good :) Even better "in the flesh" though
petavius
Post by petavius » 04 Aug 2005 07:34 pm
Sounds lovely! sm40
340GL 1984 B406 AJO - scrapped (sob)
340GLE 1987 E880 UUX
Post by foggyjames » 04 Aug 2005 08:47 pm
Yes, the sound is lovely...as is the way it goes.
10MPG is less lovely...although that's hopefully to be improved shortly!
Post by classicswede » 04 Aug 2005 09:18 pm
10MPG
Who cares at 35p a liter!!
Post by jtbo » 04 Aug 2005 09:23 pm
foggyjames wrote:Yes, the sound is lovely...as is the way it goes.
Is problem with heavy foot? ;)
I'm getting now around 31MPG, with carb I got around 20MPG, and I have now over 20% more power too :)
FI is nice :P
uldis
Post by uldis » 04 Aug 2005 09:50 pm
That sounds so good 8)
Post by foggyjames » 04 Aug 2005 10:32 pm
Your CISAC must have been SO broken...I'd only get 20 on 1 mile urban journeys from cold.
No, the problems are that they're sidedrafts - possibly the least efficient fuel system there is....and that the car isn't running properly below 3000rpm (long story - now on its way to being sorted), so the economical rev band isn't accessible.
MJ
Post by MJ » 05 Aug 2005 10:16 pm
Sounds lovely
Loking foward to hearing it on Sunday :D
Post by classicswede » 06 Aug 2005 11:20 am
You have nice roads like I do here :) Does sound nice James.
I take it you still have an air leak or is it something else?
Post by foggyjames » 06 Aug 2005 11:56 am
Why do you ask Dai...have you heard something on't vid?
If it's the bog as I first get on the power, I've spoken to Husky, and we think it's the pump jets. If it's the nasal sound at the beginning...that's just the way those carbs sound at light throttle.
Post by jtbo » 06 Aug 2005 03:17 pm
foggyjames wrote:Why do you ask Dai...have you heard something on't vid?
You still have that renix?
I do suspect that vacuum thing in renix is not workin as it should after all these years.
It is because I get this bog too, not as bad but still is there and sometimes it is worse sometimes not so bad, if I drive without vacuum hose connected to renix it is always same kind.
I have come up with two plans now, one is to source two hei 4-pin modules and coil so I can build ignition to megasquirt and use renix flywheel and sensor, plan 2 is to use B19e ignition module and hall sensor in distributor. Just need money right now, cost won't be much over 100 for each setup but I'm currently missing that 100 euros :(
It will be near winter or mid winter when I get my budget ready for those and I don't have a garage.
