Please introduce yourself here, your Volvo 300 hobby... NO technical support, parts requests or car advertisements here
An another day off the work...
For me it means an another day with the Volvo. So I woke up this morning and decided to garb a screw driver and started my very own Anti-Rust Project.
I took off the rust first with the screwdriver and then with sandpaper.
Then I used a brush to put on a layer of zinc based paint. After it had dryed I painted the spots white with brush again.
The result:
As you can see, I'm a lousy painter... but it still looks better than in the morning.
Just a suggestion: don't forget that some of your rust problems mean internal rust problems... Your external treatment is good but if you do nothing inside the 'closed' places, rust will appear again very quick... For example here: (for the doors it's ok)
Collection: '78 343 Black Beauty, '82 345 GLS, '83 340 DL 2.0, '84 340 DL vario, '88 360 GLT 5d (2x) & 4d (2x), '89 GLT, '91 340 vario Dad's cars: '87 340 vario, '89 340 vario
Lot of donors cars and parts... V3M for life!
Good luck Juha. An anti-rust project is quite an undertaking, lots of small bubbles of rust become big holes when attacked with a screwdriver Hope you have lots of waxoil to spray inside the cavities. That picture by Duvel78 is SO familiar .
i usually use smoothrite where it can be seen,hammerite when out of sight.you dont need primer and a small tin goes a long way if a good brush is used.no good for some people as colour range is not good and im not sure if it would mix,suppose it should tho. like most things the preperation is most important.
will have to do mine before the winter comes,its fast upon us.
