gear problem
gear problem
evening again.
any comments on what might be causing my 2nd to need significantly more muscle to get it into the slot? the other gears are fine if more agricultural than my 4 speeder just 2nd is a hassle.
regards
regards
1986 1.4DL - 147,000 - C746 VRT
- antiekeradio
- antiekeradio
second gear problem
common problem of 300-series. because of the "long" clutch shaft syncro works in difficult conditions, especially when changing from first to second too fast! any oil cannot solve that worn item in the gearbox. i am using old type of changing from 1st to 2nd - as everybody used to do it on non-syncronized gearboxes. you can try this on yours!
A fairly common problem - try adjusting the reverse gate over to the left slightly, as this solved the problem on my last few 300's.
To gain access, undo the 2 screw in front of the gear lever & remove bag. This then exposes the reverse gate (this is why you lift the collar on the stick to clear this) which is held by 2 screws. Slightly slacken these & move it say 1/2 mill over to the left - this then gives more slack on the gate.
Before you do the above, waggle the stick from side to side in first & then second. You should find that there's a lot less play in second which is the problem !!
Cheers,
John.
Cheers,
John.
Current : No 300's anymore !
- foggyjames
Thumbs up for John's suggestion. I just adjusted my switch, as my lights weren't coming on at all (opposite problem!), but it's a fine line between having the lights on reliably, and 1st, 2nd, or both being hard to engage.
If that doesn't work, look to the mechanical solution. Much easier to swap complete boxes.
- foggyjames
I think 'drivesavolvo' was offering one for £50, but I think you could do better than that if you got lucky.
I'd say it'll have to have had a hard life to be knackered at 130k.
