Question about fuel tank
mgarageu
Post by mgarageu »
i wonder if i can use a plastic fuel tank from diesel
340 in petrol engine 360? the old fuel tank is damaged by rust badly and i cannot find better
one. i have a plastic one from diesel 340. may i put it on? i have 360 with B19A engine... :?:
Duvel78
Website Admin
Post by Duvel78 »
Mmmm, that's a good question and I don't have the answer
at this moment. I didn't know it was a PLASTIC tank on the 340 diesel! sm66 I thought it was
the same tank on the 340 1.4, 1.7 and diesel. sm74 I've learned something! sm69 I will try
to get the answer...
What I know it's that you can't use the tank of a 340 1.4 because it's completely different:
the hole for the durits is under the back seat with the 2.0 engine but it's in the trunk for the
1.4... The capacity is also different...
Petrol is maybe too "aggressive" for a plastic tank? sm14
mgarageu
about plastic fuel tank
Post by mgarageu »
all 400 series and 700 volvos have
plastic tanks, but i do not know the chemical formulas of these! maybe they are similar? :?:
volvo360
Post by volvo360 »
Duverl78 is right, the gas tanks between 340's and 360's are
completely different.
To be a little more exact: the 340 gastank takes up the space reserved for the spare (which of
course is located under the hood) whereas the 360 tank is placed partly over the gearbox and
rear differential (spare is placed normally under the trunk carpet).
Can't remember exact volumes right now, but as I recall, the 360 tank is something like 67
liters in size...
I remember reading something about an extra tank that Volvo was offering for the 300-series...
but then, as I'm not sure, this is pure speculation.
Cheers,
Ari
Duvel78
Website Admin
Post by Duvel78 »
Yep, perfectly explained!
According to someone on the French forum, the tank for the 340 diesel seems to be the same
as for the 360... And he said that it wasn't a problem the plastic tank. I just need one more
confirmation and it will be ok! sm69
V3M for life!
Luu
Finland
Post by Luu »
Sorry my bad english!
I have diesel 340 and it has dieseltank under back seat. Material is blastic.
Diesel engine is too big to but spare under hood.
Duvel78
Website Admin
Post by Duvel78 »
Luu wrote:Sorry my bad
english!
Don't panic! My English is also bad but it's not a problem... We are here to share our
passion! sm40
V3M for life!
Julios
Post by Julios »
Hi, according to Volvo parts catalogue there are three similar
fuel tanks that could be fitted in the Volvo 340/360. One for the fuel injected (B200E/B19E)
engine and one for the carburettor (B200K/B19A)engine. The third one is the one fitted to the
Diesel engine (D16). Each has a different part number but what I could figure out from the
pictures is that the diesel fuel tank is similar to the carburettor engine.
360GL
Post by 360GL »
As this is my first post, I would like to say hello to everybody.
Fuel tank capacities for petrol cars are:
340: 45 L
360: 57 L
I have no information for diesel.
Only make the change if everything fits perfectly, including the connections to the tank, and
sender unit otherwise it may be a safety hazard. Also try to get an opinion from a professional if
plastic is good for petrol.
Maybe you could find the 360 tank at some scrap yard?
87 360GL B200K
wstrik
Post by wstrik »
The fuel tank of a diesel may be placed under the rear seat but
according to the folders, it's a different capacity from the 360: a 360 (in every guise) has 57
litres, a diesel only 48 (or 46 in other folders), which is just slightly more than the aft tank of a
340 (45 litres).
mgarageu
tanks metal, tanks plastic
Post by mgarageu »
the question is mainly about plastic
tank and petrol compatibility...
no difference about liters...
the replacing is quite difficult job. it is because i want to use the plastic one...
wstrik
Post by wstrik »
Yes I know. But as the size isn't the same, the tank won't be
the same. It could be so that the diesel-tank doesn't have room for the driveshaft, which is
beefed-up on a 360 and isn't on a 340. So the only way to be sure is: place the to next to
each other, and spot the differences.
mgarageu
petrol or diesel tanks
Post by mgarageu »
the only question is:
-are petrol and the plastic,used to produce the diesel tank,compatiblle? :?:
Duvel78
Website Admin
Post by Duvel78 »
Well well well...
I'm afraid that the answer is "no"
According to a member of the dutch Volvo 300 club, the plastic isn't compatible with petrol...
sm16
V3M for life!
mgarageu
plastic tank
Post by mgarageu »
is it someones opinion or does he know it really?
all 400 series have plastic?
