Need help with Solex! Quick!
Where should this hose be connected? Should it be connected?
that might be the 'outside air temperature sensor' tube thingy. if you cant find anything to plug it into, then turn the engine on and see if it works
Swapsea-'89 360GLT-swapped!
That looks vaguely like the vacuum hose from the carb to the Renix unit. It alters the timing for cold starts etc.
True, but it doesn't look as if there have been any clamps/clips on the end of it which is why I ruled out fuel line. It looks like it pushes onto whatever it connects to. I agree it looks like fuel line though, maybe someone used some instead of vacuum line?Janitor wrote:strange for it to be braided though!!?? its hard to tell from photo the size of internal hole diameter.if its small its usually vaccum,petrol return pipe if its large(if they have1?).
It's been a few years (9) since my Mum sold her 1.7 so I'm going on memory of the engine bay.
My money is also on the vacuum feed to the Renix unit. That is easily determined....is there a hose attached to your renix unit?!
Juha wrote:Please excuse me for my poor automotive english... What is a renix unit?
Never heard the word before. Could someone explain?
I found this hose hanging free when I was changing the thermostat.
It's the control unit for the ignition system, used instead of a coil on certain engines. It will have the main High Tension Lead to the distributor coming from it.
I had similar hose in my b200k, it has something to do with fuel level in carb.. Kohokammion tuuletus in finnish
I still need to practise automotive english
Anyway my carb sucked air and sand from there. I then cleaned that valve that is in carb side of that hose and then put filter into hose, now engine runs much better because valve actually works
I'm 95 % certain its the ventilation hose from the top of the float chamber. If you look on the side of the top of the carb, there will be a place for the hose to just push on and then it just hangs round toward the back of the engine, presumably if it overflows then it directs the petrol down the back of the clutch housing rather than all over the red hot engine.
A garage pulled ours off the car and it was a year before we noticed it and put a new piece on it.
