Next question!
petavius
Next question!
Post by petavius »
Ok, I am replacing my passenger side wing, we got to the stage of undoing the bolts around the top, front and under wheel arch but now have to tackle the ones behind the door. Any tips on the easiest way of removing the door hinges? This door will have to go back on as I havent found a suitable replacement yet but i have got a new pair of hinges.
340GL 1984 B406 AJO - scrapped (sob)
340GLE 1987 E880 UUX
Post by 340GLT »
Dont need to take door of Gem, undo the check strap between the hinges and you should be able to get a 1/4" drive socket and extension behind the door to undo them. If you put it in the gap at the top and slide them down the gap.
Cheers Adam
petavius
Post by petavius »
Thanks Ad. Couldn't see the middle bolt at all thus taking off the door seemed the only way to get to it. Looked from every angle but just can't see where the bolt is and we have only got standard tools. We are looking to take the hinge pins out tomorrow to get the door off - any advice? Unless we are missing something really obvious!
V6 Man
Post by V6 Man »
Try using a 10mm socket of the 1/4" variety on a long extension bar. It won't go in straight onto the middle nut, but will do at an angle which is enough to undo it.
petavius
Post by petavius »
Lovely - thanks!
petavius
Post by petavius »
Job done, found lots of rust on the wheel arch but gave it a good dose of waxoyl! New wing is on and is sound as a pound - different colour but who cares right! Next job doors.
