Last week my Volvo 360 GLE with a B200E engine broke down. I think I´ve traced the fault to between the ignition and the relay between the ignition and the ignition spool. Can this be correct and how can it be fixed? Does anyone have any other ideas of what the problem might be?
Thankful for every response!
Jonas
My car won´t start
Can you give us any more details of what exactly is happening? Is it cranking over properly? Are the ignition warning lights coming on properly?
These cars can develop bad electrical connections so if you suspect something electrical, its worth rotating all the fuses, and also unplug, clean with electrical cleaner spray and replug the three multiplug connectors inside the fusebox, and also inside the car, behind the fusebox.
