300/400 series temperature sender
Duvel78
Website Admin
Post by Duvel78 »
And my webcam is good for the parts in my room :D
V3M for life!
5lab
Post by 5lab »
take yer pc outside then! job done :)
Swapsea-'89 360GLT-swapped!
Duvel78
Website Admin
Post by Duvel78 »
Ha ha! With a laptop ok... But it's a big home computer here!
V3M for life!
5lab
Post by 5lab »
so.. take it outside! or bring hte car in if its easier ;)
Duvel78
Website Admin
Post by Duvel78 »
Of course, the car in a flat... sm56
V3M for life!
Post by foggyjames »
The connections you're looking for are in the loom behind the dash. They're a pair of spade connectors.
If you're lazy, you can connect the brown wire to ground at the sender, rather than running it all the way back to the gauge.
Duvel78
Website Admin
Post by Duvel78 »
Thanks James!
I won't be lazy at all and remove the dashboard cause I have to install the electrical mirrors this week.
V3M for life!
Have fun - getting the wires through the rubber trunking into the door is a horrible job. I've got that joy facing me again in the coming weeks when I try to figure out why my electric mirror (only one installed so far!) has stopped working.
5lab
Post by 5lab »
i'm planning to do my wires by threading thru some garden twistthingys (you know - its like wire in a flat plastic coating, thats quite rigid) then tieing it to the wires and pulling it back thru the hole...
The major problem you have is with the 'door end' of the rubber 'snake' thing. I won't tell you what's fun about it...I'll let you figure it out ;)
