Brake upgrade Project (Disks all round) Completed!!
- 340GLT
Right update time, the brakes are nearly bedded in now and i am getting a good feel of the pedal now.
When i first set it all up and took it out the brakes were spongy but it would still lock up a front wheel at low speed!!
In total the brakes have been bled 5 times!!
At speed the brakes dont need to be used past half pedal otherwise the braking is to heavy, it slows down very rapidly and at low speeds like 5mph, on tarmac it WILL lock both fronts if you jab the pedal!!
They will need minor adjustment and i want the handbrake to lock up, but i will need more of the pad surface worn on the back before i can adjust them up.
I feel its a very acomplished setup and am very pleased with the results!! I definatley recommend something for those of you going to stupid power!!
As for the suspension thats pretty gud too now, i chucked it round a tight bend on the way back from work and she was nearly totally level, just turned straight in!!
Gulbrandsen_Racing
Gulbrandsen_Racing
Gulbrandsen_Racing
alistairolsen
