Cornholio
Posts: 921 Joined: 21 Jul 2005 01:29 pm
Post
by Cornholio » 20 Jul 2006 11:50 am
After hearing Pete's 'wheel nut / windscreen' horror story, I've eventually (
) ventured into my tool box to retrieve the torque wrench.
Is there any difference between steel and alloy wheels? I remember checking the nuts on Sausage (steel) but have never done it with Rory (alloy).
In fact, dare I be so bold as to ask if anyone knows how tight they should be?
Thank you!
Gavin.
Posts: 7943 Joined: 21 Sep 2004 12:45 pm
Post
by SteveP » 20 Jul 2006 12:05 pm
They're supposed to be 110nm, as courtesy of Andy who I asked about this yesterday!
Cornholio
Post
by Cornholio » 20 Jul 2006 12:06 pm
Thank you!
mac
Posts: 1403 Joined: 19 Apr 2006 11:02 am
Post
by mac » 20 Jul 2006 01:08 pm
Had this question in a PM yesterday.
For 300 series recommended torque is 115Nm (about 85lbf.ft) (some sources give 110Nm).
For 400 series recommended torque is 110Nm (about 81lbf.ft)
The above is given for both alloy and steel wheels so I would suggest it is not absolutely critical. I would suggest you use the 300 figure and as with all alloy wheels recheck tightness every so often (and one week after fitting).
Mac.
990
Posts: 485 Joined: 04 Sep 2005 12:24 pm
Post
by 990 » 20 Jul 2006 01:10 pm
That means I need to check the alloys this weekend then
Volvo 360 -- Small Car - BIG Ideas
E990 UBA Volvo 360GL - Vanised
D133 OBU Volvo 340GL - Died
F330 FWB Volvo 360GLT - She Runs
GJ53 GPF Volvo S60 - Daily
Cornholio
Post
by Cornholio » 20 Jul 2006 02:19 pm
Thank you Mac
Posts: 5432 Joined: 05 Oct 2004 10:18 am
Post
by redline » 20 Jul 2006 03:05 pm
I usually just tighten my nuts until I go blue in the face and get short of breath
dont know if this is of any help to you Gavin
Cornholio
Post
by Cornholio » 20 Jul 2006 03:47 pm
Thank you Mr Redline. Maybe a bit too much information there.
Trying hard not to visualise it.
Posts: 5805 Joined: 23 Jul 2004 03:50 am
Post
by jtbo » 20 Jul 2006 04:12 pm
redline wrote: I usually just tighten my nuts until I go blue in the face and get short of breath
I do usually stop when I'm in red phase
Also put some grease to threads so I can open them later, that is easy part as need to use only body weight and not so much muscles
Volvo 343DL vario -81 -running-
Citroen ZX Dturbo -97 -daily-
Post
by redline » 20 Jul 2006 04:13 pm
no , its not rude I have one of those extendable thingys !!!!!!
I will try to find a picture for you Gavin
Post
by redline » 20 Jul 2006 04:20 pm
well it took a bit of searching but it was worth it this thing gets longer when you need to use it , sits comfortably in the palm of your hand you have to twist it a bit to get the desired effact but with very little exertion loosens off the tightest of nuts
Cornholio
Post
by Cornholio » 20 Jul 2006 04:22 pm
[edit] Please Mick, no pictures
Post
by redline » 20 Jul 2006 04:27 pm
oops , got so excited I forgot the picture
Cornholio
Post
by Cornholio » 20 Jul 2006 04:29 pm
Phew, that's a relief.
(No pun intended)
