Hi again ppl,
I am trying to get a list of things that need to be changed to fit PAS to an australian 360GLT and seeing as they dont exist here it is a little difficult.
so far i know;
-Pump (and bracket)
-Rack (which is the only part i have)
-Hoses
-narrow thermatic fan
-engine pipe and its bracket
-Lower steering column and those heat sheild things
Is there anything else that is different? and does the rack affix using the same clamps as the non-PAS rack?
it would be much appreciated if someone could take a pic of how the pump is mounted and what the bottom of the steering column looks like?
I am also interested in buying these parts if anyone has access to them but i guess this is not the place to be asking that
easiest way to get power steering is a couple of extra ibs psi in the front tyres and start working out your upper arms .
it can have srious side effects with the sheilas though lol
Oh so true! but 5 years of this workout should be enough for me for a little while,
That and it will be the only one in Aussie with PAS
The pic only adds a sense of urgency to getting it
Well, I've got one complete PAS conversion set removed, but Ali has that earmarked. I'm pretty sure I've got a complete system on another car that I'm breaking. I could save everything that's different or needed for you, that's if someone else can't come up with the bits sooner if you're in a rush!
well i pretty much need everything but the rack itself and the pump (with its bracket) as i have those,
so.... all the other little bits n bobs like rack brackets, steering column, hoses, oil tank bracket etc. etc.
would that be possible?
ooh and how much would you do that for?
I have seen and driven one 360 GLT with PAS is australia, so they do exist here. I also saw one advertised once. Volvo mechanic told me he had only seen one ever.
I guess it would have had to have been an import then as one of the guys i know at a dealership said that theres no record of them ever being sold in australia..
just the other day i saw a volvo 240 at the wreckers with a sump oil heater and the mains plug in the grille , i eventually found its book and discovered that it was brought down from glasgow
petefarrell360 wrote:Well, I've got one complete PAS conversion set removed, but Ali has that earmarked. I'm pretty sure I've got a complete system on another car that I'm breaking. I could save everything that's different or needed for you, that's if someone else can't come up with the bits sooner if you're in a rush!
Oh well,
Its rare for one not to have AC here >.<
One other thing i wanted to ask is, are you wanting to sell both the PAS systems as kits? or you would be able to just sell a few parts?
cheers,
