13" steel wheels / any 300 wheels
As above I am looking to buy a couple of sets of steel / alloy wheels that will fit a 300 preferably 13".
Just need them to use for drifting so I can put all my tyres on before i go to an event.
Currently I have only got 1 set of 13inchers.
Anything you have / wanna get rid of let me know
Cheers!
Cheers!
340 GL 1987 (F) - Stripped out & Slammed Daily driver......
volvo360gle/340turbo
V6 Man
Not to try and ruin your sale Mick, but I'd be wary of using rims thatdo not have the correct hub sizing as you are putting all the strain onto the (only 4) wheel bolts. For ordinary use this may be ok, but when subjected to the extra torsional forces of drifting I feel it may be a recipe for disaster.redline wrote:I have four 13" rims from a corsa if you want them ( same pcd but slightly bigger centre bore to the volvo ) two have got good 165/70/R 13 tyres on them , £20.00 the lot , I am in Milton Keynes , p.m. me if your interested
Spigot rings
lol
tigersport
I have a set of said 13 inch steel rims, including the black spare (well its painted black) with Michelin Energy Tyres on them, with the treds being about 2.5mm on 2 and 4mm on the other 2, with the spare coming in at 3mm (but that's a Firestone). Even have the wheel trim covers for covering the bolts (totally useless for your purpose but well you know).
Ahh northern ireland could be a problem... god knows how much it would cost to send wheels from there!
Thanks anyway but I reckon it will start to cost a bit with postage etc
Tigersport - how much you wanting for your wheels? again postage could be a bit ££
I know a number of guys that have wheels with the wrong centre bore (and no spigot rings) that use them for ralling and other hard useage and have not had a problem.
The main strain in drifting is just starting to get the wheels spinning after that the strain is reduced. In fairness drifting is not by a long way the most brutal copetition use you can put a car to.
