Post
by foggyjames » 21 Dec 2006 12:57 am
Chris - are you saying you think the B200K was mis-tuned from the factory? If so, I've got some O RLY coming your way
Either way, I'd be interested to hear what you have planned!
Post
by Chris_C » 21 Dec 2006 01:07 pm
Well, it's the only carb I've every seen with the second venturi's jet is smaller than the primary, but nah, PTF wasn't tuned properly when Mick get her, I'm not even sure we checked the jet sizing against the book values now, it was a long time ago, and we prolly did. It was running shocking though, getting 30ish to a run at best at one point.
Theres a difference between mistuned and de-tuned
Post
by foggyjames » 21 Dec 2006 07:14 pm
Well....I was going to say that mine always ran niiicely
Nick C
Post
by Nick C » 23 Jan 2007 05:03 pm
It's alive!
Finally got it all back together this afternoon and took it for a test drive. It's running really lumpy whenever it's not under power, although it's fine when you put your foot down
I thought this might be due to the carb setup, but Chris reckons this is ignition timing, and can only be adjusted by changing the renix to match the cam. Has anyone got any other ideas, or a spare GLT renix I could try?
Nick
Post
by Chris_C » 23 Jan 2007 05:44 pm
Quick recap... for those like me who don't flick back through the topic, Nick's running a GLT "A" cam on stock carb.
I reckon the lumpyness is from ignition timing at low revs, and a GLT renix would cure it. Then again, we all know how much I know
pettaw
Post
by pettaw » 23 Jan 2007 09:53 pm
Its neither the carb or the timing. Well, not altogether anyway.. Its the cam
it will run lumpier on the A cam than the Y or L or whatever's in the carb one.
A GLT Renix might have a higher ignition advance at idle than the GLE cam, but tbh I would change the cam over, its an easy fix and it'll make the jetting all correct again.
Post
by classicswede » 24 Jan 2007 11:46 pm
Well I thing it is timing in a way. when you put the cam in did you put the cam to the correct side of the timing mark? It should be set slightly to the right.
