help with rattle
special
help with rattle
Post by special »
i have an anoying rattle when reving up
it sounds like valve clearence rattle however i have checked this and there all ok
the sound is comin from the bell housing area its not the clutch
the only thing i can see near it is the exhaust heat shield for the down pipe
but i cant imagine its that
any thoughts would be apreceated
(the rattles been there about 6 months but has not got any worse)
stuart :?
dare to be different
Kyuss
Post by Kyuss »
not sure if this is way off the track, but i owned a Holden Rodeo - i think this is an Isuzu Passport for you guys... and had a noise as you describe. In it's case it was the airconditioning compressor clutch which had failed.
do you have A/C and has it failed?
'84/'85 Silver 360 GLT B200E / M47R
Currenlty unroadworthy, plenty-o-rust and
missing bits. Maybe Feb '05 on the road.
special
Post by special »
er no but thanks for the sugestion anyway
5lab
Post by 5lab »
one of your exhaust mountings is snapped. should be black rubber. might be further back than your expecing (level with the b pillar maybe). replace. cost £5
Swapsea-'89 360GLT-swapped!
SoLaMaNdA
Post by SoLaMaNdA »
If its quite loud then it could be as 5lab said, an exhaust mounting rubber which I've picked up for £2. What engine is it? My 360 has rattled at exactly 2000rpm for years. I've never been able to track it down and it still runs fine.
special
Post by special »
i shall have a look at the week end thanks for the advice sm40
(whats a b pillar?) :?
Post by redline »
the one between the front and rear doors
