Final drive.
beetlebum2_uk
Final drive.
Is it possible to just change the final drive in a 340 gear box?
only asking for reference if i go down the tuned 16v route would be good to have longer legs at the top end!
anyone?
anyone?
I'm sure the final drive as per most Volvo's is 1 - 1
Your best bet would be a taller diff
beetlebum2_uk
- trabitom99
I think the carb 360s had the most long-legged diffs, something like 3.26 or 3.36 ...
beetlebum2_uk
Tis indeed! You'll notice the second gear hole a lot more with a 3.36, I notice it more in a 3.64 vs a 3.8x.
- trabitom99
I've found the post I had in mind:SteveP wrote:3.64 I think... same as GLT's... others can confirm for sure
http://www.volvo300mania.com/forum-uk/v ... hp?p=15391
Some time ago someone posted a full list of all teh different diff ratios. Does any have that list?
- foggyjames
I do, but I can almost remember all the options.
Unless you're using this setup on the motorway all day, I'd stick with the 3.82, seriously. It's ideal for a revvy NA motor which is relatively lacking in power. Save the big gears for something with bags of torque.
I've just gone from a 3.36 (standard 360 carb) to a 3.82 (340 1.4 5 speed) in my 360, and it's a big improvement when driving 'for fun'.
