does renaul 19 1.8 16v engine fit my volvo 340 1.7???
I would like to know does it fit straight into 340?!
You need to fit the 1.7 sump to the 16v engine. The biggest issue is with the inlet manifold as in std form the TB is where the heater box is. You can remove the heater box, alter the manifold or make a new one.
To save all the wiring a lot of conversions run on carbs and have a manifold made to do it
- griffo20022
As the others have said yes they do fit, F7P's found in R19's MK1 clios etc are all the same
The bellhousing from the 1.7 340 and also the 1.7 sumps needed and also as Dai said the inlet manifold needs slight customisation and also you need a custom exhaust manifold.
'90 340 1.4 Vince!
'94 BMW 325i Saloon
'94 BMW 325i Saloon
im thinking of doing this conversion to but my other car is off the road so i cant afford the volvo not to be working long,so if i got the engine and some carbs and had a manifold made how long would it take to put it all together?i alredy have a 1.7 in my volvo and have done engine swaps on jap cars but thay where all like for like.
thanks for any help
matt
thanks for any help
matt
with all the parts 2 days maxsilvia wrote:im thinking of doing this conversion to but my other car is off the road so i cant afford the volvo not to be working long,so if i got the engine and some carbs and had a manifold made how long would it take to put it all together?i alredy have a 1.7 in my volvo and have done engine swaps on jap cars but thay where all like for like.
thanks for any help
matt
thanks lee
- filthyjohn
As far as I can see (and from what I've spoken to Dai about with it) the F7R has the startor on the other side of the block, so the cut out on the block and the bellhousing will be on different sides.
I'm keen on this swap as well though John, as soon as I get my turbo running reliably, I want to properly sort out Fake for rallying, and the F7R seems a better starting point for that.
If you are going to that amount of work I'd opt for teh vauxhall lump myself. At leat the wirng side will be fairly easy as teh vauxhall has a seperate angine wiring loom.
- filthyjohn
Good job I stopped short of buying that F7R and all those williams stickers then!
Y'see I'm not that keen on the P, but the R pushes my buttons a bit more as it seems more tunable. Agreed on the XE, I loved mine, which reminds me, I must update that manta thread...
